engine lid rubber stops, two questions |
scrz914 |
Jul 21 2011, 10:57 AM
Member Group: Members Posts: 397 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California |
I was installing the engine lid after getting everything back from the body shop and noticed the hinges at different angles. Turns out one of the rubber hinge stops was missing and the other one is cracked. AA lists them for $30 each, YIKES. But it also referenced the same rubber buffer as being found in the front trunk floor. I checked mine and sure enough, they are the same.
Questions: 1. What is the purpose of the pair in the front trunk floor? My guess is they buffer the stock valance from the underbody. I have the LE style valance. 2. Where can I get some for my engine lid hinges? Has anyone come up with a cheaper substitute? Thanks for your help. |
Rand |
Jul 21 2011, 11:22 AM
Hey Mikey...
(IMG:http://www.914world.com/bbs2/uploads_offsite/oakshirefinancial.com-3573-1311268972.1.jpg) (Thinking this might be a potential product for 914rubber.com) |
scrz914 |
Jul 21 2011, 12:23 PM
QUOTE (Thinking this might be a potential product for 914rubber.com) That would be a good option but I'm guessing there wouldn't be enough demand for Mark to implement. Mine were busted up by the body shop gorillas. (IMG:style_emoticons/default/sawzall-smiley.gif) I'll probably have to rig up something from FLAPS. Still wondering what the floor trunk buffers are for. |
9146FAN |
Jul 21 2011, 09:40 PM
Member Group: Members Posts: 294 Joined: 20-July 04 From: ROSSMOOR, CA Member No.: 2,378 |
QUOTE (Thinking this might be a potential product for 914rubber.com) That would be a good option but I'm guessing there wouldn't be enough demand for Mark to implement. Mine were busted up by the body shop gorillas. (IMG:style_emoticons/default/sawzall-smiley.gif) I'll probably have to rig up something from FLAPS. Still wondering what the floor trunk buffers are for. The front rubber buffers between the front valance and the unibody are essential to stabilize the tin valance as there are no fasteners at the bottom of the valance. I hope this helps... |
scrz914 |
Jul 21 2011, 10:48 PM
Ahh. I figured it had to do with the valance. For some reason I'm having trouble visualizing it.
Still learning things about these cars. |
Pat Garvey |
Jul 22 2011, 06:48 PM
I was installing the engine lid after getting everything back from the body shop and noticed the hinges at different angles. Turns out one of the rubber hinge stops was missing and the other one is cracked. AA lists them for $30 each, YIKES. But it also referenced the same rubber buffer as being found in the front trunk floor. I checked mine and sure enough, they are the same. Questions: 1. What is the purpose of the pair in the front trunk floor? My guess is they buffer the stock valance from the underbody. I have the LE style valance. 2. Where can I get some for my engine lid hinges? Has anyone come up with a cheaper substitute? Thanks for your help. They used the same part on early 911s. Shouldn't be that tough to find. |
scrz914 |
Jul 22 2011, 08:18 PM
For now I will scavenge some off another lid I have. Too bad as it's a pretty nice original lid. I'll have to keep my eyes open for any 914 junkers and grab this part.
Towarish |
Jul 30 2011, 05:25 AM
Newbie Group: Members Posts: 49 Joined: 11-February 08 From: Germany Member No.: 8,699 Region Association: None |
I was installing the engine lid after getting everything back from the body shop and noticed the hinges at different angles. Turns out one of the rubber hinge stops was missing and the other one is cracked. AA lists them for $30 each, YIKES. But it also referenced the same rubber buffer as being found in the front trunk floor. I checked mine and sure enough, they are the same. Questions: 1. What is the purpose of the pair in the front trunk floor? My guess is they buffer the stock valance from the underbody. I have the LE style valance. 2. Where can I get some for my engine lid hinges? Has anyone come up with a cheaper substitute? Thanks for your help. Porsche genuine part 99970303650 Anschlagpuffer 0,64 € |
bandjoey |
Nov 15 2015, 10:52 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Mikey now has these in stock Perfect fit
Kansas 914 |
Nov 16 2015, 04:21 PM
Mikey now has these in stock Perfect fit http://shop.914rubber.com/Engine-deck-lid-...m?categoryId=-1 |
porschetub |
Nov 24 2015, 11:49 AM
Mikey now has these in stock Perfect fit X 1 on that just fitted a set myself,Mikey might need to up his price to keep up with AA (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) . |
Lo-Fi Version | Time is now: 27th April 2024 - 03:08 PM |
