Speedometer Drive Retaining Bolt |
p914 |
Jul 21 2011, 11:28 AM
Senior Member Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None |
The hole is stripped. I tried a helicoil but it eventually came out.
Is tapping a larger size the next step? Also, it's a regular bolt, right? No special end or tip? |
Drums66 |
Jul 21 2011, 02:44 PM
....It is a regular bolt? what size? (IMG:style_emoticons/default/biggrin.gif)
(IMG:style_emoticons/default/bye1.gif) |
Cap'n Krusty |
Jul 21 2011, 02:46 PM
Special tip. Locates the drive in the correct position so the gears mesh correctly.
The Cap'n |
p914 |
Jul 21 2011, 04:05 PM
pcar916 |
Jul 21 2011, 04:18 PM
That would work, or another boss that the bolt can screw into.
The hole in the case is threaded and the tip on the bolt locates into the hole in the drive casing. The pin isn't a tight fit in the drive-body, just a peg in a hole. An o-ring keeps the oil inside the case upstream from the locator-bolt. If you still have leakage around that o-ring, have a second groove cut into the speedo body for a second o-ring. It works better and the original should have had two anyway. One of our forum folks does a fine job of that in the vendor section. Good luck! |
underthetire |
Jul 21 2011, 04:49 PM
Forget Helicoils. Get a Keen-cert.
Mike Bellis |
Jul 21 2011, 08:40 PM
Richard Casto |
Jul 22 2011, 07:21 AM
Another alternative if that hole is really screwed up is to just source a new transmission end cover. I am sure there are a number of people on the forum who might have some extras.
Richard |
p914 |
Jul 22 2011, 01:47 PM
Dr Evil |
Jul 22 2011, 03:58 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I can repair yours with a time-cert, or I have repaired covers for sale (IMG:style_emoticons/default/smile.gif)
It is a special bolt, as stated. |
p914 |
Jul 24 2011, 02:40 PM
Thanks for all the ideas. I'm thinking a Time Sert will be my 1st try. I need to clear off the old helicoil from the screw 1st without messing it up.
Appreciate all the input (IMG:style_emoticons/default/beerchug.gif) Eddie |
Dr Evil |
Jul 24 2011, 02:48 PM
Eddie, you will need an oversize time cert, it is sold in a kit, it is not cheap. I have this kit.
p914 |
Jul 25 2011, 10:40 AM
Eddie, you will need an oversize time cert, it is sold in a kit, it is not cheap. I have this kit. Yeah, I thought I saw the kit for about $90. Is that right? I'm on the left coast so I'd have to pull the rear case off and send it. Not sure if the costs would be the same to buy the kit or send it back and forth. |
Drums66 |
Jul 25 2011, 11:46 AM
Another alternative if that hole is really screwed up is to just source a new transmission end cover. I am sure there are a number of people on the forum who might have some extras. Richard .....Did you hear this man?/ (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) |
p914 |
Jul 25 2011, 01:08 PM
.....Did you hear this man? I'd like to try and avoid that but won't rule it out. The less I have to take apart the better. |
Dr Evil |
Jul 25 2011, 02:55 PM
I can send you a good one and you send back the bad. Easy. Just pay shipping and for parts installed (certs).
PM me and we can work it out. |
Lo-Fi Version | Time is now: 21st May 2024 - 07:39 AM |
