60's Ford and Mustang performance stuff, worth l@@king over |
orange914 |
Jul 21 2011, 02:40 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
SEE VIDEO OF ALL PARTS HERE http://www.youtube.com/watch?v=u9CH5zFlCk8 50% off if you buy $300+ 3rd light, was mount very nicely on my 73 Porsche 914, will mount nice universal $25 SHIPPED 1967 390 428 mustang a/c compressor upper stabilizing bracket. $25 SHIPPED N.O.S. 1966 Ford Rotunda quart unopened brake fluid N.O.S. #C6AZ 1542 A $50 SHIPPED 1967 mustang hood turn signal harness, complete, nice original $50 SHIPPED N.O.S. 1968 ranchero torino door 4 piece window fuzzies $75 SHIPPED 1967 mustang 3 speed shifter knob $30 SHIPPED ULTRA RARE! 1967 mustang 4 speed under hood park lock out bypass factory wire plug $50 SHIPPED 60's 2 bolt H/D Ford starter $25 SHIPPED Very cool late 60's bench seat 6 way power seat track. COMPLETE! With switch, motors, wiring, 100% everything to use. Use it with any 60 and 70's bench seat, just mount and add fused hot and ground wire. Attach to your bench for 6 way adjustment $175 SHIPPED Edelbrock air cleaner $20 SHIPPED 1968 Mustang 289/302 air cleaner complete with snorkel and heat stove. This has been sitting on my shelf for years. It is in exceptional original unrestored condition, original powder coat. . . no past owner spray paint. it even has the 70's Ca. emission NOX sticker ! Not concourse/restored but nice dry Ca. $125 SHIPPED 90's hood release and cable $20 SHIPPED 2002 Ford Escort premium sound w/ c/d, face plate w/ all the climate controls $35 SHIPPED NEW 65 65 Mustang inner door panel sealing barrier $20 SHIPPED O.E. 1967 68 Mustang stereo 8track door speaker wire harness (one side) $25 SHIPPED 67 68 mustang tilt wheel vacuum pull release canister. Like new condition. Vacuum checked 100% $50 SHIPPED 67 68 mustang door lock cylinder $15 SHIPPED 70's under hood light $15 SHIPPED Early 60's falcon/ranchero factory fender ornament, rough but very replateable $20 SHIPPED Early 60's falcon/ranchero deluxe steering wheel center nice original condition $40 SHIPPED 64 thru 67 ford style steel center caps (4) for all fords, except Mustang, rough $20 SHIPPED 67 68 Mustang coupe rear window regulator. This is O.E. not aftermarket replacement junk. I believe it's the passenger side but look it over and confirm first $50 SHIPPED 1967 and before hard to find factory a/c clutch brush set $35 SHIPPED (2) 90's ford "melted" A/C plug upgrade replacement pigtails $15 SHIPPED Early 1967 and earlier Mustang Cougar small sector shaft pitman arm, washer and nut $80 SHIPPED Carter high volume fuel pump ford 390 410 427 428. Extremely low miles. Feed a 400 horse show 1967 GTA for 100 miles only. Developed a leak @ the diaphragm,. Tighten? Replace diaphragm most likely. $60 SHIPPED Crown Vic third eye brake light with mounting bracket complete. $25 SHIPPED new and used pigtails. 4 wire trailer, misc. and 2 wire pigtails $15 SHIPPED Most all of a shiny new unused interior screw kit for a 1967-68 mustang fastback $15 SHIPPED SEE VIDEO OF ALL PARTS HERE http://youtu.be/u9CH5zFlCk8 |
Lo-Fi Version | Time is now: 18th May 2024 - 07:35 AM |
