SEE VIDEO OF ALL PARTS HERE
http://www.youtube.com/watch?v=u9CH5zFlCk850% off if you buy $300+
3rd light, was mount very nicely on my 73 Porsche 914, will mount nice universal $25 SHIPPED
1967 390 428 mustang a/c compressor upper stabilizing bracket. $25 SHIPPED
N.O.S. 1966 Ford Rotunda quart unopened brake fluid N.O.S. #C6AZ 1542 A $50 SHIPPED
1967 mustang hood turn signal harness, complete, nice original $50 SHIPPED
N.O.S. 1968 ranchero torino door 4 piece window fuzzies $75 SHIPPED
1967 mustang 3 speed shifter knob $30 SHIPPED
ULTRA RARE! 1967 mustang 4 speed under hood park lock out bypass factory wire plug $50 SHIPPED
60's 2 bolt H/D Ford starter $25 SHIPPED
Very cool late 60's bench seat 6 way power seat track. COMPLETE! With switch, motors, wiring, 100% everything to use. Use it with any 60 and 70's bench seat, just mount and add fused hot and ground wire. Attach to your bench for 6 way adjustment $175 SHIPPED
Edelbrock air cleaner $20 SHIPPED
1968 Mustang 289/302 air cleaner complete with snorkel and heat stove. This has been sitting on my shelf for years. It is in exceptional original unrestored condition, original powder coat. . . no past owner spray paint. it even has the 70's Ca. emission NOX sticker ! Not concourse/restored but nice dry Ca. $125 SHIPPED
90's hood release and cable $20 SHIPPED
2002 Ford Escort premium sound w/ c/d, face plate w/ all the climate controls $35 SHIPPED
NEW 65 65 Mustang inner door panel sealing barrier $20 SHIPPED
O.E. 1967 68 Mustang stereo 8track door speaker wire harness (one side) $25 SHIPPED
67 68 mustang tilt wheel vacuum pull release canister. Like new condition. Vacuum checked 100% $50 SHIPPED
67 68 mustang door lock cylinder $15 SHIPPED
70's under hood light $15 SHIPPED
Early 60's falcon/ranchero factory fender ornament, rough but very replateable $20 SHIPPED
Early 60's falcon/ranchero deluxe steering wheel center nice original condition $40 SHIPPED
64 thru 67 ford style steel center caps (4) for all fords, except Mustang, rough $20 SHIPPED
67 68 Mustang coupe rear window regulator. This is O.E. not aftermarket replacement junk. I believe it's the passenger side but look it over and confirm first $50 SHIPPED
1967 and before hard to find factory a/c clutch brush set $35 SHIPPED
(2) 90's ford "melted" A/C plug upgrade replacement pigtails $15 SHIPPED
Early 1967 and earlier Mustang Cougar small sector shaft pitman arm, washer and nut $80 SHIPPED
Carter high volume fuel pump ford 390 410 427 428. Extremely low miles. Feed a 400 horse show 1967 GTA for 100 miles only. Developed a leak @ the diaphragm,. Tighten? Replace diaphragm most likely. $60 SHIPPED
Crown Vic third eye brake light with mounting bracket complete. $25 SHIPPED
new and used pigtails. 4 wire trailer, misc. and 2 wire pigtails $15 SHIPPED
Most all of a shiny new unused interior screw kit for a 1967-68 mustang fastback $15 SHIPPED
http://youtu.be/u9CH5zFlCk8
