could it get any worse for me. |
steveherman |
Jul 23 2011, 09:48 PM
Member Group: Members Posts: 380 Joined: 12-September 09 From: Kissimmee Florida Member No.: 10,799 Region Association: South East States |
So to continue my string of bad luck... my last operational vehicle just got towed to joes.
I am layin in my van in front of his shop. the 2008 grand caravan I purchased when my 1993 caravan was stolen. the transmission appears to be shot. yahoo |
hwgunner |
Jul 23 2011, 10:11 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
Wow, sorry to hear that. Covered by warentee?? Prob not but worth a shot, no?
steveherman |
Jul 23 2011, 10:18 PM
Unfotunately no.
Bad things with me happen in threes. So I am praying for some good. |
Mike Bellis |
Jul 23 2011, 10:27 PM
Call the dealer and see if any recall work is pending on your VIN. Many 2008-2010 Dodge/Chryslers were having shift solenoid problems. I once got a brand new tranny from Honda when the main shaft was recalled. It started acting up so I called and forund out about the recall. The dealer said it was ready to grenade on me.
wertygrog |
Jul 23 2011, 11:11 PM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
That blows! Looks like Mike has some good advice though. I hope things get better for you soon Steve!
steveherman |
Jul 23 2011, 11:21 PM
I will be calling monday for sure.
70_914 |
Jul 23 2011, 11:29 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
Sounds like my week. Wifes Jeep has a transducer that went bad in the transmission so it is in limp mode. My fuel pump just went out on my SHO that I drive everyday.
steveherman |
Jul 23 2011, 11:33 PM
steveherman |
Jul 23 2011, 11:37 PM
As I lay here in the van bored to death...
I decided to look at the underside of transmission.... it is soaked!!! I would check the fluid level but it has no dipstik. |
steveherman |
Jul 24 2011, 01:57 AM
called my dad who stays at solivita in kissimmee.
he went and picked up my girl and she took him back home so she could come get me. i am home and ugh this sucks. |
70_914 |
Jul 24 2011, 10:50 AM
As I lay here in the van bored to death... I decided to look at the underside of transmission.... it is soaked!!! I would check the fluid level but it has no dipstik. I am pretty sure you can purchase a "tool" to check your transmission fluid level. Pull the cap off the sealed tube, the one that says it is for the dealership to remove, and a dipstick will fit into it. Mercedes pulled the same "sealed" transmission trick, but their special tool is just a dipstick that costs $50. Go to Carquest near you and see if they have on through WorldPac. |
steveherman |
Jul 24 2011, 03:47 PM
You have to have the dodge scanner to check trans temperature.
then all that tool is is a regular dipstik with 10mm lines etched on the dipstik. then you put in recommended amount of mm at a certain temperature. |
Lo-Fi Version | Time is now: 18th May 2024 - 01:45 AM |
