steveherman
Jul 23 2011, 09:48 PM
So to continue my string of bad luck... my last operational vehicle just got towed to joes.
I am layin in my van in front of his shop.
the 2008 grand caravan I purchased when my 1993 caravan was stolen.
the transmission appears to be shot.
yahoo
hwgunner
Jul 23 2011, 10:11 PM
Wow, sorry to hear that. Covered by warentee?? Prob not but worth a shot, no?
steveherman
Jul 23 2011, 10:18 PM
Unfotunately no.
Bad things with me happen in threes.
So I am praying for some good.
Mike Bellis
Jul 23 2011, 10:27 PM
Call the dealer and see if any recall work is pending on your VIN. Many 2008-2010 Dodge/Chryslers were having shift solenoid problems. I once got a brand new tranny from Honda when the main shaft was recalled. It started acting up so I called and forund out about the recall. The dealer said it was ready to grenade on me.
wertygrog
Jul 23 2011, 11:11 PM
That blows! Looks like Mike has some good advice though. I hope things get better for you soon Steve!
steveherman
Jul 23 2011, 11:21 PM
I will be calling monday for sure.
70_914
Jul 23 2011, 11:29 PM
Sounds like my week. Wifes Jeep has a transducer that went bad in the transmission so it is in limp mode. My fuel pump just went out on my SHO that I drive everyday.
steveherman
Jul 23 2011, 11:33 PM
QUOTE(70_914 @ Jul 24 2011, 01:29 AM)
Did ya read my other post 2 cars stolen in 6 months?
The girl and I are in panic mode.
steveherman
Jul 23 2011, 11:37 PM
As I lay here in the van bored to death...
I decided to look at the underside of transmission.... it is soaked!!!
I would check the fluid level but it has no dipstik.
steveherman
Jul 24 2011, 01:57 AM
called my dad who stays at solivita in kissimmee.
he went and picked up my girl and she took him back home so she could come get me.
i am home and ugh this sucks.
70_914
Jul 24 2011, 10:50 AM
QUOTE(steveherman @ Jul 23 2011, 10:37 PM)
I am pretty sure you can purchase a "tool" to check your transmission fluid level. Pull the cap off the sealed tube, the one that says it is for the dealership to remove, and a dipstick will fit into it. Mercedes pulled the same "sealed" transmission trick, but their special tool is just a dipstick that costs $50. Go to Carquest near you and see if they have on through WorldPac.
steveherman
Jul 24 2011, 03:47 PM
You have to have the dodge scanner to check trans temperature.
then all that tool is is a regular dipstik with 10mm lines etched on the dipstik.
then you put in recommended amount of mm at a certain temperature.
