No long bolt on my relay board?, What holds it down |
PanelBilly |
Jul 27 2011, 08:15 AM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Originally I thought the bolt was just missing, but the board doesn't look like it ever had a bolt in it. The cover does have a hole for the bolt. Maybe it's the wrong cover
76-914 |
Jul 27 2011, 08:26 AM
The relay cover w/o the bolt is held in place by the regulator. It is installed after the cover is put on.
jcd914 |
Jul 27 2011, 08:29 AM
Originally I thought the bolt was just missing, but the board doesn't look like it ever had a bolt in it. The cover does have a hole for the bolt. Maybe it's the wrong cover I don't know when they changed but early boards and covers used the bolt and latter boards and covers did not. If you seal the hole on the early cover and you can use it on a late board, the cover just sits on the board. Jim |
AZ914 |
Jul 27 2011, 08:37 AM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Mine just fit tight over the relay board and regulator. It wasn't going anywhere.
ConeDodger |
Jul 27 2011, 08:39 AM
Apex killer! Group: Members Posts: 23,587 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Big rubber band. Oh, and I'm not kidding. It goes under the relay platform and loops over the top of the cover when it is in place. But you can just set it on there. The voltage regulator pretty much holds it in place.
JFJ914 |
Jul 27 2011, 10:31 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Originally I thought the bolt was just missing, but the board doesn't look like it ever had a bolt in it. The cover does have a hole for the bolt. Maybe it's the wrong cover You have a 75/76 board, with an early cover. The late board had a cover without the hole. Friction holds it on. |
TheCabinetmaker |
Jul 27 2011, 10:56 AM
John nailed it, and its NOT held on by the voltage regulator.
Drums66 |
Jul 27 2011, 04:25 PM
Mine just fit tight over the relay board and regulator. It wasn't going anywhere. ......Something like this......easy access (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 12:26 PM |
