RUST, what to do? |
RUST, what to do? |
Elliot_Cannon |
Apr 22 2003, 06:36 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
I am cleaning up the rust under were the battery tray used to be. The longitudinal frame piece is of course rusted through. Not a big hole but I've made it bigger cleaning up getting ready for the welder dude. What I need to know is, what can I pour or spray down in there to prevent the rust from spreading or getting worse? This must be a common porblem (I've seen some nasty pics). Is there something in a spray can or aerosol? Thanks.
Cheers, Elliot (IMG:style_emoticons/default/rolleyes.gif) |
seanery |
Apr 22 2003, 06:41 PM
Probably gonna get a lot of POR15 answers....
Lawrence |
Apr 22 2003, 06:43 PM
You can take a garden sprayer and spray in Skyco Ospho (available through Ace Hardware) or POR-15's Metal Ready. Either is a good product to use before POR-15.
-Rusty |
Elliot_Cannon |
Apr 22 2003, 07:11 PM
Sounds good. Where can I find Metal Ready and Por-15?
Elliot |
Dave Cawdrey |
Apr 22 2003, 07:30 PM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
Right here POR 15
Chris H. |
Apr 22 2003, 07:31 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
POR 15
Hey I like POR 15 as much as anyone, but if you have rust-through you should really consider replacing the bad metal with good metal. How bad is it? Just my $.02... Chris H. |
Brad Roberts |
Apr 22 2003, 08:22 PM
I would send a vaccuum cleaner down the hole (shop vac with a small hose on it) to clean up everything sitting on the bottom of the frame rail. I do this with center tunnels alot (today)
B |
Apr 22 2003, 08:28 PM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
yepp, suck it out. if the bottom is solid, spray lots of metal-ready on it. let it dry. then spray por-15 over. if it's rusted, cut it out!
Andy |
Lo-Fi Version | Time is now: 20th May 2024 - 03:54 AM |
