CV Bolt Washers, I thought schnorrs were used- what do I have? |
rjames |
Jul 28 2011, 10:32 PM
I'm made of metal Group: Members Posts: 3,939 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
When removing the CVs the bolts did not have schnorr washers but instead had washer 'plates' on both sides. Should I reuse the plates or use schnorrs? Or both?
(Sorry for the crappy cell phone pics) |
dangrouche |
Jul 28 2011, 10:43 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
When removing the CVs the bolts did not have schnorr washers but instead had washer 'plates' on both sides. Should I reuse the plates or use schnorrs? Or both? (Sorry for the crappy cell phone pics) you will need them in addition to the plates; Dr. Evil sells them. when you put them back on, you want the threads of the CV bolt to be clean and dry as well as the hubs' threads. |
Jul 29 2011, 10:48 AM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
rjames |
Jul 29 2011, 01:10 PM
QUOTE you will need them in addition to the plates; Dr. Evil sells them. when you put them back on, you want the threads of the CV bolt to be clean and dry as well as the hubs' threads. Aweomse, thanks! (IMG:style_emoticons/default/beer.gif) Mine didn't have the washers on either side. (IMG:style_emoticons/default/dry.gif) So now that I have the CVs out, it seems to make sense to inspect, clean up and repack them. Nube question, but do I do both sides of the axle? Do I need new bolts with saftey wire on both ends? Found a good video on youtube showing the rebuilding of the CV on the transmission side, but doesn't mention the wheel side of the axle. BTW, I learned that the Good Doctor is now longer selling the CV bolts and safety wire, but that RJMII (Jim) is. |
mojorisen914 |
Jul 29 2011, 03:14 PM
Visit your local strip club Group: Members Posts: 695 Joined: 9-July 06 From: Denver Colorado Member No.: 6,403 Region Association: Rocky Mountains |
When removing the CVs the bolts did not have schnorr washers but instead had washer 'plates' on both sides. Should I reuse the plates or use schnorrs? Or both? (Sorry for the crappy cell phone pics) you will need them in addition to the plates; Dr. Evil sells them. when you put them back on, you want the threads of the CV bolt to be clean and dry as well as the hubs' threads. (IMG:style_emoticons/default/agree.gif) |
Dr Evil |
Jul 29 2011, 03:39 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
RJMII sells them (IMG:style_emoticons/default/smile.gif) I gave that biz to him and he is doing well at it.
76-914 |
Jul 29 2011, 05:19 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
And don't forget to torque them. I say this because I under torqued them for years and all the while thinking I had them tight enough. It's scary how tight those need to be. (IMG:style_emoticons/default/smash.gif)
Dr Evil |
Jul 31 2011, 06:46 AM
30 ft/lb, not that tight.
Tom |
Aug 16 2011, 09:51 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
DR. Evil,
Should these be torqued dry? I have always heard to lube bolts before torquing. What kind of feed-back have you received on using your bolts and safety wire? Any stories? Thanks, Tom |
Dr Evil |
Aug 16 2011, 01:18 PM
30ft.lb is a "range." It is fine to do it dry, but I have yet to do so since grease inevitably makes it into the bolt hole. The torque is only needed to be made close. If it is 35 it will not be a problem. Too much or too little in any appreciable direction will matter more.
Lo-Fi Version | Time is now: 28th May 2024 - 08:18 AM |
