you will need them in addition to the plates; Dr. Evil sells them. when you put them back on, you want the threads of the CV bolt to be clean and dry as well as the hubs' threads.
Aweomse, thanks!
Mine didn't have the washers on either side.
So now that I have the CVs out, it seems to make sense to inspect, clean up and repack them. Nube question, but do I do both sides of the axle? Do I need new bolts with saftey wire on both ends? Found a good video on youtube showing the rebuilding of the CV on the transmission side, but doesn't mention the wheel side of the axle.
BTW, I learned that the Good Doctor is now longer selling the CV bolts and safety wire, but that RJMII (Jim) is.
