Fyrebraid Plug Wires, Worth the Money |
JawjaPorsche |
Jul 30 2011, 04:41 PM
I just replaced my 1.7 plug wires with Fyrebraid plug wires. Just got back from a test run. Can't believe how much better it runs! Plus I like the red wire look too! They look great!
JawjaPorsche |
Jul 31 2011, 08:43 AM
I just replaced my 1.7 plug wires with Fyrebraid plug wires. Just got back from a test run. Can't believe how much better it runs! Plus I like the red wire look too! They look great! I have added picture above. I like how the wires stand up away from the heat of engine. |
ripper911 |
Jul 31 2011, 08:54 AM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
I'm looking at buying new plug wires soon, where do you get these and how much are they. If you say they are worth the money, they're probably more than usual.
JawjaPorsche |
Jul 31 2011, 09:57 AM
I'm looking at buying new plug wires soon, where do you get these and how much are they. If you say they are worth the money, they're probably more than usual. Here is the link: http://www.automotion.com/ignition-wires-f...-1955-1976.html I see you live in Power Springs. I live in Clayton, Georgia. If you are ever up this way, stop by for a beer and we can talk teeners! I have 73 1.7 original owner. Terry |
ripper911 |
Jul 31 2011, 10:04 AM
Sounds great (IMG:style_emoticons/default/beerchug.gif) I'm always here, let me work out the issues I'm having now before any longish trips though.
underthetire |
Jul 31 2011, 11:18 AM
Not much more than stock at all ! I thought from the title they would be over 100 bucks!
JawjaPorsche |
Jul 31 2011, 11:52 AM
Not much more than stock at all ! I thought from the title they would be over 100 bucks! I am sorry the title was misleading. Here is another picture from the distributor side. Attached image(s) |
VaccaRabite |
Jul 31 2011, 01:47 PM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Are they spiral wound wires, or just standard core wires? Are they larger diameter then stock?
If there was a change it may have just been you needed new wires. Whats the difference between these and other aftermarket wires? Zach |
JawjaPorsche |
Jul 31 2011, 02:22 PM
Are they spiral wound wires, or just standard core wires? Are they larger diameter then stock? If there was a change it may have just been you needed new wires. Whats the difference between these and other aftermarket wires? Zach Hi Zach There is no doubt that I needed new wires! I like the fact they are stiff and don't just lay on the engine. To answer all your questions, here is the link to their website. I am sure it can answer all your tech questions. http://www.karlynsti.com/Folders/Karlyn_ST...n_Wire_Sets.htm Terry |
Lo-Fi Version | Time is now: 15th May 2024 - 11:58 PM |
