E prod 914 touches the ground |
bam914 |
Jul 30 2011, 06:13 PM
Member Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
It is finally sitting on all four wheels. Although the front suspension is only tacked together. Going to make final measurements and make sure it is close to square. Still have a lot of welding and bracing to make but it is getting closer.
Randal |
Jul 30 2011, 06:31 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
It is finally sitting on all four wheels. Although the front suspension is only tacked together. Going to make final measurements and make sure it is close to square. Still have a lot of welding and bracing to make but it is getting closer. Congratulations on getting her on the ground. Tell us about those shock towers. Look interesting. No bars to the towers or torsion bars? Maybe you can't do that with your class, but they make a big difference. If I had to do it again I'd put in the same bars, but figure out a lighter wall tubing to use. |
bam914 |
Jul 30 2011, 07:36 PM
I can put bars up there just have not done it yet. Those are next.
ottox914 |
Jul 30 2011, 09:23 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Looks great! Can those camber plates be adapted to a street car?
bam914 |
Jul 30 2011, 09:42 PM
Looks great! Can those camber plates be adapted to a street car? They could if you don't mind cutting the top of the shock tower and welding in a new one. The bearing I am using will not allow the stock strut to fit. It is too small. But a larger one could be sourced and a new bearing holder made. The plates are slightly lower then the stock set up. But I have plenty of travel with the strut setup I am using. |
stewteral |
Jul 31 2011, 11:41 AM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
It is finally sitting on all four wheels. Although the front suspension is only tacked together. Going to make final measurements and make sure it is close to square. Still have a lot of welding and bracing to make but it is getting closer. Bam914, Bravo on you low-cost and low-weight solution to camber adjustment in the front shock towers! Very clever. I have not shortened the height of my shock towers and have the dents in the hood from the Koni adjustables to prove it!! Your shocks appear to be the rebound-only adjustable Koni Sport shocks I'm running.....or have you done something special with Koni to achieve dual adjustment? Best of luck, Terry |
bam914 |
Jul 31 2011, 11:45 AM
I am using the 8611 double adjustable insert from Koni. The compression adjustment is at the bottom of the strut.
Chris Pincetich |
Aug 1 2011, 07:03 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I see more heim joints (IMG:style_emoticons/default/beerchug.gif)
bam914 |
Aug 1 2011, 07:41 PM
Yep it is all heim joints including the rear.
jhadler |
Aug 8 2011, 01:47 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Yep it is all heim joints including the rear. Pictures please? (IMG:style_emoticons/default/smile.gif) And what became of the awesome IT motor? -Josh |
bam914 |
Aug 8 2011, 04:07 PM
I sold the IT engine to my friend who is building a DSP 914. I am in the process of rebuilding it and making the changes to make it a legal AX engine.
Here is a link to my post about the rear suspension. http://www.914world.com/bbs2/index.php?sho...=134389&hl= |
Lo-Fi Version | Time is now: 28th May 2024 - 01:46 PM |
