air compressor will not atart |
914itis |
Jul 31 2011, 05:22 PM
(IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/WTF.gif) I have a two weeks old air compressor from hf, the pneumatic 21 gallons, it will not start in the middle of priming. it spins and the circuit beaker goes off. if i remove the pressure valve then it starts. any ideas? is anyone here using this POS?
wingnut86 |
Jul 31 2011, 05:49 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
I remember seeing posts related to that and a few other models.
They all complained of a high slag content inside the tank, blocking the pressure from release, etc. Once removed it ran flawlessly - Frikkin little Ninja's inside it (IMG:style_emoticons/default/beer.gif) Is there a large enough drain plug for you to open and shine a high output light into? Not sure if a magnet extension would work, but what the hell, see what you can attract. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/WTF.gif) I have a two weeks old air compressor from hf, the pneumatic 21 gallons, it will not start in the middle of priming. it spins and the circuit beaker goes off. if i remove the pressure valve then it starts. any ideas? is anyone here using this POS? |
914itis |
Jul 31 2011, 06:04 PM
I remember seeing posts related to that and a few other models. They all complained of a high slag content inside the tank, blocking the pressure from release, etc. Once removed it ran flawlessly - Frikkin little Ninja's inside it (IMG:style_emoticons/default/beer.gif) Is there a large enough drain plug for you to open and shine a high output light into? Not sure if a magnet extension would work, but what the hell, see what you can attract. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/WTF.gif) I have a two weeks old air compressor from hf, the pneumatic 21 gallons, it will not start in the middle of priming. it spins and the circuit beaker goes off. if i remove the pressure valve then it starts. any ideas? is anyone here using this POS? tha hole are so small I can't see insie the tank. |
underthetire |
Jul 31 2011, 06:18 PM
I use one, the 110 one. Never had problem one with it. I'm betting the re-start pressure relief valve inside the switch is clogged or sticking. This causes a dead head on start, blowing your breaker.
dangrouche |
Jul 31 2011, 07:12 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
I have this 110volt 21 gallon HF one as well; ran very well for first 18 months, then it suddenly kept kicking off and I had to reset the circuity breaker. The culprit was the relay. I substituted a blade-type fuse and holder instead of the relay and it solved the problem. You will have to string the wiring outside so that you can replace the fuse. I could not find this relay for cheap nor could I find it stocked anywhere. I think I was running it continuously too much and the circuitry got too hot and the plastic melted slightly. Has run smoothly since.
Attached thumbnail(s) |
914itis |
Jul 31 2011, 07:20 PM
dangrouche |
Jul 31 2011, 07:30 PM
this is not the o/off switch; mine is red knob that you pull up to start the compressor. This is the relay somewhere on your shrouding, besides your on off swith. This is basically a temperature sensitive relay that kicks the power off when the unit gets too hot from running continuously too much. if you only had the unit for two weeks, bring it back and try to get a new one. these things are made in China and are really light duty.
914itis |
Jul 31 2011, 08:54 PM
oh well, I will return that crap in the morning. I know i may be fighting them since I don't need that brand anymore. I am not sure what is their policy for selling garbage, but I may have to fight it with amex. we will seee what happen.
underthetire |
Jul 31 2011, 08:57 PM
I use one, the 110 one. Never had problem one with it. I'm betting the re-start pressure relief valve inside the switch is clogged or sticking. This causes a dead head on start, blowing your breaker. The on / off switch? If it's like mine, there is a small line going to the on off lever switch pressure switch assembly. When the compressor shuts off, it relieves the pressure from the cylinder. Without it working it will dead head and blow at start up. Mine is the vertical tank one. |
914itis |
Jul 31 2011, 09:15 PM
I use one, the 110 one. Never had problem one with it. I'm betting the re-start pressure relief valve inside the switch is clogged or sticking. This causes a dead head on start, blowing your breaker. The on / off switch? If it's like mine, there is a small line going to the on off lever switch pressure switch assembly. When the compressor shuts off, it relieves the pressure from the cylinder. Without it working it will dead head and blow at start up. Mine is the vertical tank one. I have a 9 gallon vertical, my son gave it to me for Xmas. I didn't use it until may, I had the same issue from the start. It was too late to return it, figured I got a bad one. I went and got a new 221 gallons 10 volts, Have it for a few weeks, was working fine until today. if feels as the engine is having hard time turning, then blows the beaker. if i persist, they blow my house's breaker. same symptoms on both. I am getting a craftsman |
Lo-Fi Version | Time is now: 16th May 2024 - 12:19 PM |
