I remember seeing posts related to that and a few other models.
They all complained of a high slag content inside the tank, blocking the pressure from release, etc. Once removed it ran flawlessly - Frikkin little Ninja's inside it
Is there a large enough drain plug for you to open and shine a high output light into?
Not sure if a magnet extension would work, but what the hell, see what you can attract.
QUOTE(ppetion @ Jul 31 2011, 07:22 PM)
I have a two weeks old air compressor from hf, the pneumatic 21 gallons, it will not start in the middle of priming. it spins and the circuit beaker goes off. if i remove the pressure valve then it starts. any ideas? is anyone here using this POS?
