Wires to cut in a 75 from under the passenger seat, What can go? |
PeeGreen 914 |
Aug 2 2011, 04:46 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
It is my understanding the everything that goes to the relay under the seat is not needed. The only wire to worry about is the big yellow wire. Is my understanding correct? I want to rid myself of all unwanted wires.
PeeGreen 914 |
Aug 2 2011, 05:05 PM
Oh, and where is the best place to cut them? (IMG:style_emoticons/default/confused24.gif)
Cap'n Krusty |
Aug 2 2011, 05:07 PM
It would probably be easier for us to answer you if the picture actually showed the wiring of which you are speaking. Unless, of course, you mean the bundle running through the tunnel ...............................
The Cap'n |
jt914-6 |
Aug 2 2011, 05:15 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
On my '74 I connected the large yellow ones together. There is a small guage black with red stripe that is hot with the key. You'll need to "cap" off the end so it doesn't touch ground. The rest can be cut wherever you wish. On my '75 I put a off/on switch in the back of the center storage tray (hidden by the pad) and attached the yellow ones to it. Turn the switch off when not driving it and the car can't be started.
PeeGreen 914 |
Aug 2 2011, 05:16 PM
You need to see pictures of the wires to know what wires go to the relay under the passenger seat of a 75?
Well then.... it is the bundle I have zip tied together in this picture. Attached image(s) |
PeeGreen 914 |
Aug 2 2011, 05:18 PM
On my '74 I connected the large yellow ones together. There is a small guage black with red stripe that is hot with the key. You'll need to "cap" off the end so it doesn't touch ground. The rest can be cut wherever you wish. Awesome, that is what I was told and thought but I wanted to double check before I begin. Thanks. (IMG:style_emoticons/default/beerchug.gif) |
Aug 2 2011, 05:19 PM
Splice the big yellow wire to the big yellow wire. Leave the others in place, unless you are really desperate to get rid of little tiny bits of weight.
In which case you should look at wires that are already crimped together at the terminal under the seat. Crimp those wires together closer to the main wiring harness. Cover all crimps with shrink-tubing. Unless you never get water or dirt inside your 914... (IMG:style_emoticons/default/rolleyes.gif) --DD |
Cap'n Krusty |
Aug 2 2011, 05:37 PM
You need to see pictures of the wires to know what wires go to the relay under the passenger seat of a 75? Well then.... it is the bundle I have zip tied together in this picture. I merely wished to point out that a picture purporting to show the parts in question should actually show those parts. BTW, there are a lot of '75s out there that don't even have those wires or the logic relay itself. The Cap'n |
Jeffs9146 |
Aug 2 2011, 05:50 PM
Splice the big yellow wire to the big yellow wire. Leave the others in place, unless you are really desperate to get rid of little tiny bits of weight. In which case you should look at wires that are already crimped together at the terminal under the seat. Crimp those wires together closer to the main wiring harness. Cover all crimps with shrink-tubing. Unless you never get water or dirt inside your 914... (IMG:style_emoticons/default/rolleyes.gif) --DD (IMG:style_emoticons/default/agree.gif) If you just cut and cap them and not connect them together you will loose your Clock, Seatbelt Warning Light, Oil Pressure Switch, Oil Pressure Indicator Light, Key Warning Buzzer, Both Door Switches, Interior Light, Brake Warning Switch ect............ (IMG:style_emoticons/default/blink.gif) |
PeeGreen 914 |
Aug 2 2011, 06:00 PM
Splice the big yellow wire to the big yellow wire. Leave the others in place, unless you are really desperate to get rid of little tiny bits of weight. In which case you should look at wires that are already crimped together at the terminal under the seat. Crimp those wires together closer to the main wiring harness. Cover all crimps with shrink-tubing. Unless you never get water or dirt inside your 914... (IMG:style_emoticons/default/rolleyes.gif) --DD (IMG:style_emoticons/default/agree.gif) If you just cut and cap them and not connect them together you will loose your Clock, Seatbelt Warning Light, Oil Pressure Switch, Oil Pressure Indicator Light, Key Warning Buzzer, Both Door Switches, Interior Light, Brake Warning Switch ect............ (IMG:style_emoticons/default/blink.gif) Well, I'm not too worried about losing those things. This is an autocross car. |
Jeffs9146 |
Aug 2 2011, 06:55 PM
QUOTE Well, I'm not too worried about losing those things. This is an autocross car. Ohhhhhhhh you didn't tell us that before!! (IMG:style_emoticons/default/confused24.gif) By all means Cut Away!! (IMG:style_emoticons/default/beer.gif) |
7275914911 |
Aug 2 2011, 07:09 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
If you just cut and cap them and not connect them together you will loose your Clock, Seatbelt Warning Light, Oil Pressure Switch, Oil Pressure Indicator Light, Key Warning Buzzer, Both Door Switches, Interior Light, Brake Warning Switch ect............ (IMG:style_emoticons/default/blink.gif) Not to hijack, Jon.. but can someone(Jeff) descibe the wire colors mentioned above. I assume the Color Wiring Chart will be my friend. Is that PP?? I have that bundle of wire and everything appears to have been hacked off. I have mysterious trouble with some of the above mentioned items. Possible ground issues too.. I hate electrical.....thats why I have not tackled this project yet |
PeeGreen 914 |
Aug 2 2011, 07:44 PM
Hijack away Ken (IMG:style_emoticons/default/beerchug.gif)
Aug 2 2011, 11:29 PM
Yes, Pelican has the full-color wiring diagram for the 74.
--DD |
Jeffs9146 |
Aug 2 2011, 11:54 PM
Yes PP has it for the 74 but it is hard to read! I have the Red Manuals for the 75 and the color diagrams on one large 4 foot page so it is a bit easier! I will try to help where I can! (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 04:52 PM |
