QUOTE(Dave_Darling @ Aug 2 2011, 04:19 PM)
Splice the big yellow wire to the big yellow wire. Leave the others in place, unless you are really desperate to get rid of little tiny bits of weight.
In which case you should look at wires that are already crimped together at the terminal under the seat. Crimp those wires together closer to the main wiring harness.
Cover all crimps with shrink-tubing. Unless you
never get water or dirt inside your 914...
--DD
If you just cut and cap them and not connect them together you will loose your Clock, Seatbelt Warning Light, Oil Pressure Switch, Oil Pressure Indicator Light, Key Warning Buzzer, Both Door Switches, Interior Light, Brake Warning Switch ect............
