Terminal 1, 4, and 15 on the coil |
turnaround89 |
Aug 3 2011, 12:13 AM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
So im taking my car back to fuel injection and im going to bypass the relay board. Ive been looking in my haynes manual at the wiring diagram and the coil shows three terminals. My newest coil has a + and - sign on it with double post terminals. What ive gathered so far and just want to make sure im close or maybe correct in reading the diagram.
Terminal 1 would be the (-) side of the coil because the tach signal wire comes off that post(blk/purple wire) as well as a green wire that goes to the distributor which i think would be the condenser wire. Off of terminal 4 comes a black wire that also goes to the distributor. What wire is this and where does it attach to the distributor? Lastly, where is terminal 15 on the coil? The diagram points to the back of the coil, but there isn't anything there. May be a stupid question but i have no idea what terminal 15 is A little info, my car has been completely rewired by myself not using a stock wiring harness. I wired up the ignition using the simple ignition circuit shown by lapuwali. Here is how my ignition circuit is wired up, the starter switch in the picture, is actually a relay. |
70_914 |
Aug 3 2011, 01:07 AM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
15 is the power from the ignition switch. + side of coil
1 is the reference from the distributor. - side of coil 4 I have no clue... need to check my book. I am sure others will chime in, and I am going off memory (I have a 4 year old and a 7 month old, not enough sleep for good memory...) |
benalishhero |
Aug 3 2011, 05:21 AM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Like Kevin said
15=+ 1=- perhaps 4 is the coil wire to the cap? |
type47 |
Aug 3 2011, 05:47 AM
http://www.pelicanparts.com/914/parts/Elec...lectric_74E.jpg
Looks to me that the coil in in/on tracks 84-90. Terminal 4 is the coil to the distributor cap. |
Cap'n Krusty |
Aug 3 2011, 07:48 AM
By German standards, conventional ignition coils are designated (1) for the negative side, (15) for the positive side, and the "coil wire" for the actual spark is (4). Bosch coils have the (1) and (15) embossed right on the top of the coil. Your tachometer wire will be connected to (1), as well. The entire key on power circuit for the ignition and many other functions is called (15).
The Cap'n |
turnaround89 |
Aug 3 2011, 09:26 AM
Awesome, thanks everyone. The actually spark plug wire from the coil to dizzy didn't even occur to me that that is what the wire would be. You guys helped solve a major problem i had. Thanks everyone so much
Lo-Fi Version | Time is now: 16th May 2024 - 04:00 AM |
