A.A.R. hook up- -75 2.0 d-jet - new runners, a.a.r etc., putting things back together- does it matter which is in and out? |
DRPHIL914 |
Aug 4 2011, 07:28 AM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
does it make a difference which way is in, and which one is out to the cold start valve.?
here are a few before and afters on this too! phil runners were powdercoated gloss silver by Barry in N.C. , throttle body and plenum from Detoxcowboy! thanks guys! Attached thumbnail(s) |
Tom |
Aug 4 2011, 09:19 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Don't think it matters, but easier to run the one from the plenum to the lower one. Looking good!
Tom |
luskesq |
Aug 4 2011, 09:22 AM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
Yes, arrow on the valve (on the electrical connector) should point to the passenger side (pg 42 Haynes for D-jet). When I first got my 914 ('70, 1.7) when it was started it had a very strong gas smell. Discovered the valve had been reversed.
Runners look sweet. Keith |
SUNAB914 |
Aug 4 2011, 09:46 AM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
looks great, don't forget to check with Savannah powder coating for prices.
914_teener |
Aug 4 2011, 07:53 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
DRPHIL914 |
Aug 4 2011, 08:42 PM
looks great, don't forget to check with Savannah powder coating for prices. What fuel pressure gauge did you use and your source? Thanks....thinking of doing the same. Thanks. I got it from advanced auto but I have a better source. That was for a acura. And I had to go to lowed for parts. Go to ecstuning.com under porsche 914 they have one for $29.95 By the way, she started up tonight. ! |
DRPHIL914 |
Aug 6 2011, 09:58 PM
So since I was stripping and repainting the original air cleaner I decided to try this. Actually works good. Idle will be a little higher, it breathes so much easier when accelerating. Along with new t.b. and accelerator cable its so different from before! Once it warms up I think idle will be about 1100rpm. I did not run it long enough to get hit and have the a.a.r. close, but once everything tightened up and I plugged the accessory unused holes on the top of the plenum, idle was fairly smooth, for the first time in 6 months.
I kind of like being able to see the clean runners and compartment. Now tomorrow-- (IMG:style_emoticons/default/driving.gif) Attached thumbnail(s) |
Tom |
Aug 7 2011, 09:14 AM
Hey Dr. Phil,
In your photo your #3 spark plug wire is running really close to where your MPS should be. That can cause problems. There is currently a thread running about that exact problem. Solution is to run the wire under the intake runner for #3. Glad to hear it's running! Tom Edit: here is the thread http://www.914world.com/bbs2/index.php?showtopic=138759 |
DRPHIL914 |
Aug 7 2011, 01:30 PM
Hey Dr. Phil, In your photo your #3 spark plug wire is running really close to where your MPS should be. That can cause problems. There is currently a thread running about that exact problem. Solution is to run the wire under the intake runner for #3. Glad to hear it's running! Tom Edit: here is the thread http://www.914world.com/bbs2/index.php?showtopic=138759 Tom, Thanks for the reminder. I knew that but forgot. will do it. phil |
70-914nut |
Aug 7 2011, 08:03 PM
Member Group: Members Posts: 119 Joined: 15-March 11 From: Elizabeth city nc Member No.: 12,826 Region Association: None |
Thanks for the props Phil the plenum will be on the way tommorrow and it will look a lot better than the one thats on there. It turned out real nice!
Lo-Fi Version | Time is now: 21st May 2024 - 11:03 AM |
