Done, Done |
Done, Done |
fastmover34 |
Aug 4 2011, 04:33 PM
Newbie Group: Members Posts: 12 Joined: 7-October 10 From: Las Vegas, NV Member No.: 12,250 Region Association: None |
Done
GaroldShaffer |
Aug 4 2011, 05:05 PM
For the eyebrows just pull it out. You should be able to reuse the rubber tips.
76-914 |
Aug 4 2011, 05:36 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You should be able to cock it at an angle then pull it out. I think the spade connector is preventing you from getting it at the right angle to pull out. Also, IIRC it is partially accessible from the inside of the car from behind the speaker panel? Don't hold me to it. I get hit in the head alot.
Aug 4 2011, 05:46 PM
You should be able to cock it at an angle then pull it out. (IMG:style_emoticons/default/agree.gif) There's one angle where it will come out, you need to play with it a bit more. I forget which way. But they come out easy once you hit the right spot. As for the eyebrows, you can just press the rubber plugs out. DO NOT use bolts! They are rubber for a reason. If you like your fingers still attached to your hands, you'll reinstall the rubber plugs ... (IMG:style_emoticons/default/shades.gif) |
markb |
Aug 4 2011, 05:51 PM
You should be able to cock it at an angle then pull it out. (IMG:style_emoticons/default/agree.gif) There's one angle where it will come out, you need to play with it a bit more. I forget which way. But they come out easy once you hit the right spot. As for the eyebrows, you can just press the rubber plugs out. DO NOT use bolts! They are rubber for a reason. If you like your fingers still attached to your hands, you'll reinstall the rubber plugs ... (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/agree.gif) |
SLITS |
Aug 4 2011, 05:58 PM
Youse guys forgot to tell anyone to pull the headlight relay prior to raising the headlight with the knob.
Yep, I said knob! |
toolguy |
Aug 4 2011, 07:19 PM
Senior Member Group: Members Posts: 1,268 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Push them through with a small screwdriver best to put a little rubber lube on them first as there are another of the things you can't get anymore. . . .The reason they are rubber in the first place is so the smile will move if something {Like your finger] get caught when the headlight goes down. . . if you break them you suckin bad. . the two from the inside trunk are required. . you can use a piece of straight fuel line for the inner fender well one. . . of if you dont' care if it looks original you can use rubber grommets in their place.
Lo-Fi Version | Time is now: 20th May 2024 - 08:20 PM |
