QUOTE(76-914 @ Aug 4 2011, 04:36 PM)
You should be able to cock it at an angle then pull it out.
There's one angle where it will come out, you need to play with it a bit more. I forget which way. But they come out easy once you hit the right spot.
As for the eyebrows, you can just press the rubber plugs out.
DO NOT use bolts!They are rubber for a reason. If you like your fingers still attached to your hands, you'll reinstall the rubber plugs ...
