Oil Temps and how long to get there? |
Kerrys914 |
Jul 1 2004, 01:48 PM
Okay with average street driving around town with a little hwy driving...How long should it take for the oil to reach normal operating temp? I drive for 20 mins and it doesn't seem to come off 120F?? (IMG:style_emoticons/default/headbang.gif)
I figure 220F is normal. Cheers (IMG:style_emoticons/default/beer3.gif) Kerry |
Jul 1 2004, 02:39 PM
Resident German Group: Admin Posts: 41,653 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
195F - 205F would be optimal, 220 is a bit high already, 240 is HOT.
what gauge and sender are you running? i tried my 911 gauge with the stock TV sender and got similar results. never got over 150F. guess it's time for a new sending unit ... Andy |
Kerrys914 |
Jul 1 2004, 02:43 PM
I bought a new VDO gage and sender (to match) so I was told. (IMG:style_emoticons/default/headbang.gif)
Jul 1 2004, 02:45 PM
QUOTE(Va914 @ Jul 1 2004, 01:43 PM) I bought a new VDO gage and sender (to match) so I was told. (IMG:style_emoticons/default/headbang.gif) stupid question, but ... do you have numbers on your gauge? Andy |
Rusty |
Jul 2 2004, 01:04 AM
I had a similar problem in my 74 2.0. Are you using the upgraded (slightly smaller, numbered) VDO gauge in the center console?
When I installed mine, I was getting some power to the gauge/sender, but the gauge just didn't work. I bought a second new gauge/sender set - same problem. But the OLD guage worked! I played with this FOREVER until I started looking at the connector on the new gauge. The wire positions aren't the same on the new gauge. The connector will fit, but wires are in the wrong place. I pulled the old connector apart, put the wires right on the temp gauge - voila! Hope this helps, Rusty (IMG:style_emoticons/default/smoke.gif) |
Kerrys914 |
Jul 2 2004, 05:41 AM
Hummmm (IMG:style_emoticons/default/ohmy.gif)
(+) is a fused constant 12v (-) ground (S) Is the wire to the sender I think when I change the oil next I will pull the sender and see if I can run some tests on it. Cheers and thanks guys |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:46 PM |
