20W-50 Brad Penn, Don't Use in Winter? |
JawjaPorsche |
Aug 5 2011, 07:59 AM
I had a mechanic say don't use 20W-50 in the winter. Is he correct? Our winters in Georgia usually are in the 20's at night and 40 to 50 in the daytime.
I use Brad Penn oil. Thank you in advance. |
carr914 |
Aug 5 2011, 08:04 AM
Racer from Birth Group: Members Posts: 118,648 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
What's Winter?... oh it comes around with that stuff called snow
You're in Georgia, you should be fine |
Jake Raby |
Aug 5 2011, 08:57 AM
What's Winter?... oh it comes around with that stuff called snow You're in Georgia, you should be fine He is located near me in the Mountains of NE Georgia, above 2,500' elevation. Last winter we had temperatures near zero and a foot of snow. All of Georgia isn't warm and its too cold for BP 20/50 in winter in this area. |
Aug 5 2011, 10:36 AM
I found two things.
If I used the 20/50 oil in the winter, I could blow out oil seals when its cold and it barely cranked. Second, I dont drive the car in the winter anymore...so YMMV I only really had the issue below 20 degrees...and we can get nights into -20 on occasion. Nothing really starts well in that weather, so the lighter oil at least helps a bit. Cant crank over 20/50 in those temps. Rich |
Jake Raby |
Aug 5 2011, 11:33 AM
The pour rate of Brad Penn isn't as great as other 20/50 oils. The only downfall to our Snake oil is that it has a greater pour rate and simply cannot be used in temps less than 50 degrees. I learned this is last year's winter testing.
Lake Speed and I are working on a 10/40 version that should be the perfect middle of the road oil. |
p914 |
Aug 5 2011, 11:39 AM
Senior Member Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None |
The pour rate of Brad Penn isn't as great as other 20/50 oils. The only downfall to our Snake oil is that it has a greater pour rate and simply cannot be used in temps less than 50 degrees. I learned this is last year's winter testing. Lake Speed and I are working on a 10/40 version that should be the perfect middle of the road oil. An old friend of mine and I used to waterski in Jackson MS back in the 70s and he was friends with Lake. Nice guy and a good skier |
Jake Raby |
Aug 5 2011, 06:28 PM
This is Lake's son, Lake Jr.
He is the director of the Joe Gibbs Driven Racing Oil division... He and I work very well together and see eye to eye :-) He is also a WKA champ, along with his Dad. |
Tom_T |
Aug 12 2011, 05:09 AM
IIRC the owners manual (that little book in the glovebox) says 5-30W in winter.
It's weight or viscosity related - not brand related, unless BP doesn't make the proper winter weight oil. |
Lo-Fi Version | Time is now: 16th May 2024 - 06:27 PM |
