JawjaPorsche
Aug 5 2011, 07:59 AM
I had a mechanic say don't use 20W-50 in the winter. Is he correct? Our winters in Georgia usually are in the 20's at night and 40 to 50 in the daytime.
I use Brad Penn oil.
Thank you in advance.
carr914
Aug 5 2011, 08:04 AM
What's Winter?... oh it comes around with that stuff called snow
You're in Georgia, you should be fine
Jake Raby
Aug 5 2011, 08:57 AM
QUOTE(carr914 @ Aug 5 2011, 07:04 AM)
He is located near me in the Mountains of NE Georgia, above 2,500' elevation. Last winter we had temperatures near zero and a foot of snow. All of Georgia isn't warm and its too cold for BP 20/50 in winter in this area.
r_towle
Aug 5 2011, 10:36 AM
I found two things.
If I used the 20/50 oil in the winter, I could blow out oil seals when its cold and it barely cranked.
Second, I dont drive the car in the winter anymore...so YMMV
I only really had the issue below 20 degrees...and we can get nights into -20 on occasion.
Nothing really starts well in that weather, so the lighter oil at least helps a bit.
Cant crank over 20/50 in those temps.
Rich
Jake Raby
Aug 5 2011, 11:33 AM
The pour rate of Brad Penn isn't as great as other 20/50 oils. The only downfall to our Snake oil is that it has a greater pour rate and simply cannot be used in temps less than 50 degrees. I learned this is last year's winter testing.
Lake Speed and I are working on a 10/40 version that should be the perfect middle of the road oil.
p914
Aug 5 2011, 11:39 AM
QUOTE(Jake Raby @ Aug 5 2011, 10:33 AM)
An old friend of mine and I used to waterski in Jackson MS back in the 70s and he was friends with Lake. Nice guy and a good skier
Jake Raby
Aug 5 2011, 06:28 PM
This is Lake's son, Lake Jr.
He is the director of the Joe Gibbs Driven Racing Oil division... He and I work very well together and see eye to eye :-)
He is also a WKA champ, along with his Dad.
Tom_T
Aug 12 2011, 05:09 AM
IIRC the owners manual (that little book in the glovebox) says 5-30W in winter.
It's weight or viscosity related - not brand related, unless BP doesn't make the proper winter weight oil.
