Batery relocation |
Batery relocation |
914itis |
Aug 5 2011, 12:17 PM
I am thinking of relocating my battery to the rear trunk. I think that if i do so, it may interefere with the targa beeing stored in the trunk. I have seen it done here but I am not sure if the targa still fits there, or what dimension the battery should be for proper clearance.
PeeGreen 914 |
Aug 5 2011, 12:29 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I am thinking of relocating my battery to the rear trunk. I think that if i do so, it may interefere with the targa beeing stored in the trunk. I have seen it done here but I am not sure if the targa still fits there, or what dimension the battery should be for proper clearance. All the ones I have looked at that have been relocated had no issue. I think most of them tried to center it just above the crossmember. |
stugray |
Aug 5 2011, 01:03 PM
I was thinking of cutting a hole in the rear trunk and recessing a battery box into the floor.
I just want to wait until I decide where I will mount the oil cooler before cutting a hole. This is for a racecar, so I dont mind cutting the hole, and getting the weight as low as possible is of some help. Stu |
Aug 5 2011, 01:31 PM
I am thinking of relocating my battery to the rear trunk. Why? (IMG:style_emoticons/default/confused24.gif) If you are going to relocate it, IMHO put it as *low* in the car as possible ... (IMG:style_emoticons/default/stirthepot.gif) Put it in the passenger footwell, against the front firewall. That's as low as you can get, plus it offsets the weight nicely to the center and right. Then put a nice box around it and it can double as a passenger foot-rest. (IMG:style_emoticons/default/beerchug.gif) |
brant |
Aug 5 2011, 01:33 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
these cars are rear heavy.
all weight needs to be moved forward to improve handling moving it backwards and higher is the exact opposite of what should be done. |
76-914 |
Aug 5 2011, 01:52 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Has Porsche ever published a datum point on these cars?
EdwardBlume |
Aug 5 2011, 02:26 PM
I've done it. It fits fine. Keep it on the pass side to keep things balanced.
914itis |
Aug 5 2011, 02:54 PM
Rand |
Aug 5 2011, 02:59 PM
I am just curious, What's so heavy on the driver's side that would make it unbalanced? I am guessing the alternator? The driver. (IMG:style_emoticons/default/poke.gif) |
914itis |
Aug 5 2011, 03:05 PM
I am just curious, What's so heavy on the driver's side that would make it unbalanced? I am guessing the alternator? The driver. (IMG:style_emoticons/default/poke.gif) o....k, I was thinking about that I have a passenger 80% of the times. was the 914 made to ride alone? |
PeeGreen 914 |
Aug 5 2011, 03:14 PM
Well, I'm not sure how they weight balanced these cars like they did but there are places that will benefit from adding weight and removing weight. I am moving my battery right behind my passenger seat as I am using a small light Odyessy. The well prepared 914's I have seen have the battery where the gas tank was on the passenger side (they are running ful cells). Passenger or not...go low.
914itis |
Aug 5 2011, 03:19 PM
One of my main concern is that everytime I attemp to move it on my existing teener, I worry about scraping the paint, it's so tight in there to get it in and out. With my new project, I didn't want to worry about that.
Andyrew |
Aug 5 2011, 04:42 PM
Why are you moving your battery so often?
I have an optima battery and put in a new one every 5 years or more. Thats the only time I move the battery. |
Aug 5 2011, 04:50 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
someone here was making mechanics bibs that covered the fenders and rear trunk.
I cant remember who, but do a search and see if they are still making them. Rich |
smontanaro |
Aug 5 2011, 08:02 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
EdwardBlume |
Aug 6 2011, 05:37 AM
I moved the battery on a former street / ax car that I had the HH repaired on. I figured it would be cleaner just to cut the tray out and call it a day.
Balancing weight is kind of a misnomer... you can adjust a 914's suspension for the weight of the driver, but its not the best on tires if you are shaving 1/8s off your daily commute.... |
Lo-Fi Version | Time is now: 21st May 2024 - 12:24 AM |
