Head temp sensor, Intall |
Cambo |
Aug 5 2011, 01:45 PM
Member Group: Members Posts: 122 Joined: 21-April 10 From: California Member No.: 11,641 Region Association: Northern California |
Do you have to remove the intake runners to remove/install the cylinder head temp sensor? It seems a little tight to get in there. 75 1.8 FI
76-914 |
Aug 5 2011, 01:49 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I did not on a 2.0 DJet. Can't speak to a 1.8 LJet. Remember that it is at a small angle to the head when reinstalling one.
rhodyguy |
Aug 5 2011, 01:53 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
if you sacrifice the appropritate deep well socket with a grinder slice up the side you can get the wire out of your way. clean the sharp edges on the slice.
k |
underthetire |
Aug 5 2011, 01:55 PM
Soak that sucker in PB blaster for a day or two before you try and remove it. They can and will pull the threads right out of the head if they have been in a while.
rhodyguy |
Aug 5 2011, 01:56 PM
try a 1/4" drive socket.
RFoulds |
Aug 5 2011, 02:01 PM
Green Teen 66 Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
Soak that sucker in PB blaster for a day or two before you try and remove it. They can and will pull the threads right out of the head if they have been in a while. this is a MUST do, because once you break it off, the only way its coming out is dropping the engine.. |
Cambo |
Aug 5 2011, 02:11 PM
Soak that sucker in PB blaster for a day or two before you try and remove it. They can and will pull the threads right out of the head if they have been in a while. this is a MUST do, because once you break it off, the only way its coming out is dropping the engine.. Yikes! Thats good to know! |
Aug 5 2011, 02:33 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
if you are removing the one that it in there...just cut the wire.
Deep socket on the new one, tuck all the wire up into the socket. RIch |
swl |
Aug 5 2011, 08:31 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Do you have to remove the intake runners to remove/install the cylinder head temp sensor? It seems a little tight to get in there. 75 1.8 FI same issue with the 1.7 engine. Unless it is going in on an angle it looks like the drive wouldn't get past the runner. I've only had an intial look at it - haven't tried to get it out yet. Let me know how it works out for you. |
luskesq |
Aug 5 2011, 10:07 PM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
You don't need to remove the runner on a 1.7. I like Rich's approach with jamming the wire into the deep socket. I took a slightly different approach. To a China (cheap) made 3/8th extension and cut a vertical groove up one corner, wide enough for the lead to fit into. Feed the wire up through your socket and attach the extension. You can hand onto the wire so it doesn't fall out of the socket. I used a bit of hot glue on the gasket so it wouldn't fall off also.
Keith |
914_teener |
Aug 6 2011, 12:04 AM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
You don't need to remove the runner on a 1.7. I like Rich's approach with jamming the wire into the deep socket. I took a slightly different approach. To a China (cheap) made 3/8th extension and cut a vertical groove up one corner, wide enough for the lead to fit into. Feed the wire up through your socket and attach the extension. You can hand onto the wire so it doesn't fall out of the socket. I used a bit of hot glue on the gasket so it wouldn't fall off also. Keith (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 09:57 AM |
