Welded 9x16 Fuchs, Your opinion please. |
racerbvd |
Aug 11 2011, 09:04 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
If I didn't have any wheels, I would be going for a set of 17" Rota Fuchs, $1,200 for a set of 7&9s and there are more tire choices. But then again, there are some people who are hard headed (like me, just check my blog & look at the parts for my GT clone (IMG:style_emoticons/default/huh.gif) ) and inist on having OEM parts..
Madswede |
Aug 12 2011, 12:33 AM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
You know, I'm kinda the same way. In the past, I've been vocal about my complaints about how 'boring' or 'typical' Fuchs are, but then once I really decided upon them, I don't want knock offs very much.
Call me a purist, call me what you will. My thinking was that if they're going on my car, and I'm really trying for the whole enchilada, then ... well hell, while replicas look the shit, I just can't abide them. Something about OEM forged wheels. They are typically lighter than most imitations out there, from my limited research. 'course I plan to commit a mild sacrilege and paint the centers something other than black ... |
Twise |
Aug 12 2011, 04:27 PM
Member Group: Members Posts: 475 Joined: 20-September 06 From: SoCal - Temecula Member No.: 6,881 Region Association: Southern California |
Thats kinda what I thought - Purist Thing.
I had a set of oems all lined up to buy, we have an account with automotion, so I had dave send me one wheel to check out. They looked same/same, so I spent the extra money on spherical mounts. I mean cmon 9x16's are just getting ridiculously expensive. Pure as the driven snow here, but sense = cents... As far as weight goes, if I cared one wit about that fuchs would not even be in the equation. |
PRS914-6 |
Aug 12 2011, 06:36 PM
I think there is an error in thinking here.....Rim size and the proper tire vary depending on the series.....For instance you have been discussing a 245/50 series tire which in my opinion is too large. If you drop to the more appropriate 245/45 tire than the rim size should indeed be a 9" wheel
If you want "crisp handling" then use the widest recommended wheel. In this case the widest for 245/45/16 would be a 9 inch wheel..... |
Madswede |
Aug 13 2011, 02:35 AM
Thats kinda what I thought - Purist Thing. I had a set of oems all lined up to buy, we have an account with automotion, so I had dave send me one wheel to check out. They looked same/same, so I spent the extra money on spherical mounts. I mean cmon 9x16's are just getting ridiculously expensive. Pure as the driven snow here, but sense = cents... As far as weight goes, if I cared one wit about that fuchs would not even be in the equation. I can't really argue with you on any one point of that. I guess I'm just gonna be bone-headed and start out with real fuchs and go from there. I might be getting (IMG:style_emoticons/default/sheeplove.gif) by tire companies (I'm rather entertained by how many posts include tires that I don't particularly want and/or are track/slicks), but that's just something I want to deal with and learn from I guess. To each their own! (IMG:style_emoticons/default/beerchug.gif) EDIT: Jeez, coming after the last post it looks like I'm specifically knocking you, Paul. Not my intention, sorry. Teach me to read all posts before replying. Anyway, I was trying to say that if the best tire size is as wide as you can go for what the rim will accept, there's very few (besides the Fuzion that you quoted) that are available in that size. Note the high price and the "closeout" marking as well as "less than two" available. It's a concern with that size, so I'm looking more towards a slightly taller profile series (being the 245/50). Guess I'll just try 'em and learn. |
Katmanken |
Aug 13 2011, 05:40 PM
One thing that a lot of people don't realize is that welding aluminum can screw up the strength of the base material. Other than forging, not sure of the exact process used to form the wheels. Two ways to strengthen aluminum. One is forging which "work hardens" the aluminum, and the second is heat treat of the material to a T4 or T6. When you weld, the weld pool is moved back to T0 which is annealed dead soft. If the surrounding material is heat treated to T4, welding can move it back to T0. If the material is forged, the weld pool isn't. Adding the T4 or T6 heat treat after welding may strengthen the material -if the filler weld rod is capable of precipitation hardening.
What does this mean? T4 Heat treating 6061 moves base T0 from 18000 yield to 30,000 yield. T6 on 6060 alloy moves the yield to 42000. Bottom line? Welded areas on aluminum wheels are weaker than the original forged and/or heat treated aluminum wheels. Are they strong enough? Don't know. Wrong process can result in big material change. Caveat emptor. Let us know how they work out. Ken |
sixnotfour |
Sep 4 2011, 12:34 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/confused24.gif) Off my 84 930 ten years ago, when I went to Fiske's , The car was sold and totalled by the new owner.
Available Attached image(s) |
Series9 |
Sep 4 2011, 02:46 PM
(IMG:style_emoticons/default/confused24.gif) Off my 84 930 ten years ago, when I went to Fiske's , The car was sold and totalled by the new owner. Available Those are 7&9x16? How much? |
sixnotfour |
Sep 4 2011, 03:31 PM
Yes, and Nelson and I made a deal, they will be at RRC.
Madswede |
We have a deal for those beauties! (IMG:style_emoticons/default/shades.gif) [EDIT: simul-post with above] Will bring the $ to RRC, thanks Jeff.
sixnotfour |
Sep 4 2011, 03:34 PM
I have lottsa of Fuchs,Torque Thrust, Fuchs 3 piece,BBS 3 piece,Daisy wheels,Welded Fuchs, Tell me what you want and what you are willing to pay, Otherwise I will be on the Hoaders Show. No question, Specific request and I will let you know. Jeff
Jeff Gamaroth got my last hoard, 24ft trailer worth=stupid, but the wife was happy. Thanks Jon, see you @ RRC |
Madswede |
Sep 4 2011, 03:41 PM
Just so there's no confusion, Joe was asking for my car he's building in FL. We all happened to be online at the same time, fortuitously. They're going to Series9 after we pick 'em up at RRC.
sixnotfour |
Sep 4 2011, 09:58 PM
yes no confusion , I did email Joe as i needed to know today. thanks agian Jon & joe
racerbvd |
Sep 5 2011, 10:21 AM
I have lottsa of Fuchs,Torque Thrust, Fuchs 3 piece,BBS 3 piece,Daisy wheels,Welded Fuchs, Tell me what you want and what you are willing to pay, Otherwise I will be on the Hoaders Show. No question, Specific request and I will let you know. Jeff Jeff Gamaroth got my last hoard, 24ft trailer worth=stupid, but the wife was happy. Thanks Jon, see you @ RRC Glad to know I'm not the only one, but I don't have a wife to bitch about my wheels to I'm holding on to my Fuchs.. |
campbellcj |
Sep 5 2011, 11:02 AM
I can't Re Member Group: Members Posts: 4,547 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
LOL, Byron and I thought I had a wheel problem. I maxed-out at a mere 6 sets... now down to 3 finally.
A set of 17x9's and 10's may be in my future once my bank account recovers from the major trauma of this spring/summer. |
Sep 5 2011, 11:03 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Any Porsche Cup II wheels (17 inch) in either of your stashes?
And,cause I assume you guys know, do these fit with no issues on an 84 911 carerra? I am shopping for a 17 inch wheel that bolts onto the carerra for winter tires... Rich |
Lo-Fi Version | Time is now: 31st May 2024 - 10:47 PM |
