More 'new' engine goodies, parts back from the powder coaters |
moparrob |
Aug 6 2011, 05:21 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
After cleaning up my '79 3.0 big port engine I decided to dress up some of the parts and make it look halfway respectable. So, I bead blasted the fan and housing, then took the valve covers, air cleaner bases and rain hats down to the local poweder coater for final prep and coating. The work was done at Ajax's in Van Nuys.
After speaking with the owner I decided to accept his suggestion to use 'outgas' black coating in light of the fact the fan and housing are cast magnesium. He explained this coating fires at as lower temperature which reduces the likelihood of having contaminant and other porosity related issues develop. I think the results are excellent and he did a good job masking the parts from over spray. Here is the engine before: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672866.1.jpg) The coated fan: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672866.2.jpg) the housing: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672866.3.jpg) Rain hats: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672866.4.jpg) lower valve covers: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672867.5.jpg) upper covers: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672867.6.jpg) as you can see I masked them and filed the coating of the letters "PORSCHE" (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672867.7.jpg) The finished product: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672867.8.jpg) Overall I'm very pleased. Now to get it re-assembled and into the car.... (IMG:style_emoticons/default/piratenanner.gif) |
Randal |
Aug 6 2011, 05:26 PM
After cleaning up my '79 3.0 big port engine I decided to dress up some of the parts and make it look halfway respectable. So, I bead blasted the fan and housing, then took the valve covers, air cleaner bases and rain hats down to the local poweder coater for final prep and coating. The work was done at Ajax's in Van Nuys. After speaking with the owner I decided to accept his suggestion to use 'outgas' black coating in light of the fact the fan and housing are cast magnesium. He explained this coating fires at as lower temperature which reduces the likelihood of having contaminant and other porosity related issues develop. I think the results are excellent and he did a good job masking the parts from over spray. Here is the engine before: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672866.1.jpg) The coated fan: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672866.2.jpg) the housing: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672866.3.jpg) Rain hats: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672866.4.jpg) lower valve covers: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672867.5.jpg) upper covers: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672867.6.jpg) as you can see I masked them and filed the coating of the letters "PORSCHE" (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672867.7.jpg) The finished product: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1312672867.8.jpg) Overall I'm very pleased. Now to get it re-assembled and into the car.... (IMG:style_emoticons/default/piratenanner.gif) Nice work on the powder coating. Engine is going to look beautiful. (IMG:style_emoticons/default/dry.gif) |
patssle |
Aug 6 2011, 05:47 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Before you fully assemble everything, check that the fan will still spin. I had mine powdercoated and it was too thick, the blades rubbed against the housing. I had to sand down the edges.
moparrob |
Aug 6 2011, 10:31 PM
Absolutely correct. the powder coater told me the exact same thing due to the close tolerances.
Lo-Fi Version | Time is now: 21st May 2024 - 03:57 PM |
