What, Where?, fuel injection |
Eck |
Aug 6 2011, 08:26 PM
Newbie Group: Members Posts: 10 Joined: 1-August 10 From: Kansas Member No.: 12,000 Region Association: None |
Where does the wire I have circled go? It wasn't attached to anything so I'm trying to figure out why it wasn't attached and where it should go.
Thanks Kirk Attached image(s) |
swl |
Aug 6 2011, 08:31 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
I believe that goes to the cold start thermoswitch. Visible in this picture on the bottom left of the plenum. Just behind the coldstart valve itself.
http://www.914world.com/bbs2/index.php?act...t&id=269525 Only used in very cold weather - around freezing or in that neighbourhood. |
markb |
Aug 6 2011, 09:27 PM
AAR?
PancakePorsche |
Aug 6 2011, 10:53 PM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
Where does the wire I have circled go? It wasn't attached to anything so I'm trying to figure out why it wasn't attached and where it should go. Thanks Kirk For sure the lead for cold start thermo switch. Mine is located just behind the distributor (1973) bracket on plenum. |
914_teener |
Aug 7 2011, 12:12 AM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Where does the wire I have circled go? It wasn't attached to anything so I'm trying to figure out why it wasn't attached and where it should go. Thanks Kirk For sure the lead for cold start thermo switch. Mine is located just behind the distributor (1973) bracket on plenum. Go to Jeff Bowlsby's site. He has a wiring diagram for the harness. I agree. Cold start thermoswitch |
JFJ914 |
Aug 7 2011, 10:49 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
That looks like the cyl head temp sender wire. It should have a 1/4" male spade conn and a big rectangular plastic insulator on it.
Bartlett 914 |
Aug 7 2011, 10:58 AM
That looks like the cyl head temp sender wire. It should have a 1/4" male spade conn and a big rectangular plastic insulator on it. (IMG:style_emoticons/default/agree.gif) CHT between the injectors and the MPS connector |
swl |
Aug 7 2011, 11:23 AM
I don't think so John/Mark. The CHT should be in the first cluster with #3 injector lead.
Jeff Bowlsby has done a great job documenting the harness http://bowlsby.net/914/WiringHarnesses/HarnDia_FI_EA-EB.jpg CHT is "E" and the thermoswitch is "K". Interesting though that the CHT lead doesn't show in that picture. Maybe behind the harness itself |
Eck |
Aug 7 2011, 12:22 PM
I have a plug for the CHT, that is what has me puzzled. Doesn't the CHT take two wires? This is a single. I'll go to Jeff site and check it out.
Thanks Kirk |
swl |
Aug 7 2011, 12:30 PM
single wire. return path is through engine ground. same thing for the thermo switch
Eck |
Aug 7 2011, 12:32 PM
Steve you got it! It is the Thermotime switch.
Thanks everyone. Kirk |
Lo-Fi Version | Time is now: 21st May 2024 - 02:42 AM |
