Oil Temp gauge, what else will I need? |
Socalandy |
Aug 7 2011, 11:28 AM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
Well with the hill climb for RRC coming soon I'm installing a temp gauge but see alot of confussing topics on what all is needed to get Rrrrr done.
Is this it and if not do I need a 2.0 sensor plate? (IMG:style_emoticons/default/blink.gif) Thanks Attached image(s) |
76-914 |
Aug 7 2011, 12:33 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you have the green/blk sender wire in place, that's it. Oh yea, you might want to check the polarity if your using the factory harness plug. Mine had the + & S flipped from what the incremental gage that you're showing, uses.In fact I think I damaged mine by doing so. (IMG:style_emoticons/default/headbang.gif)
Lo-Fi Version | Time is now: 21st May 2024 - 02:28 AM |
