Well with the hill climb for RRC coming soon I'm installing a temp gauge but see alot of confussing topics on what all is needed to get Rrrrr done.
Is this it and if not do I need a 2.0 sensor plate?
Thanks
76-914
Aug 7 2011, 12:33 PM
If you have the green/blk sender wire in place, that's it. Oh yea, you might want to check the polarity if your using the factory harness plug. Mine had the + & S flipped from what the incremental gage that you're showing, uses.In fact I think I damaged mine by doing so.
