5-lug / Big Brake (front) Update Package, for early ball joints |
ArtechnikA |
Aug 7 2011, 04:43 PM
"Some Assembly Required" but all the important bits.
Used parts: ======= 2 (L+R) 3-1/2" Brake Saddle early (pinch-bolt) ball joint struts. 2 (L+R) 914.6 / 911 5-lug hubs 2 8614-1077 Koni Adjustable Gas Dampers - 914 valving. 2 (L+R) 911S calipers with low-miles early 930 pads. 2 trochoid-pattern slotted vented disks. Some surface rust from storage but no wear ring. New: === Not shown but included: 2 911s caliper rebuild kits, including Stomski stainless pistons. 2 sets (as required for S calipers) Speed Bleeders. You will need: new bearings in the hubs. Disk mounting hardware. Bearing thrust washers and clamp nuts. Dust covers unless I find a pair, in which case they're included. Short brake hardline (FLAPS). I have never seen a set of struts like this before: some clever and skilled person took a pair of Boge hydropneumatic struts and welded in a Koni-mount threaded collar. It looks an excellent weld job - I didn't notice it until I was pulling off the gland nut to extract the dampers - which explains a bit, since I didn't believe there were any big-brake pinchbolt Boge struts - turns out there aren't - except this pair. Interesting what you find. $350 plus shipping - this stuff is heavy, sorry. Can deliver to the PaDelMarVa pool party August 27 |
Type 4 Unleashed |
Aug 7 2011, 04:53 PM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
I'll take it all.
Will send PM |
41ghost |
Aug 7 2011, 05:45 PM
Member Group: Members Posts: 235 Joined: 13-July 04 From: noblesville,in. Member No.: 2,345 |
I'm second in line if they don't sell.
Lo-Fi Version | Time is now: 29th May 2024 - 07:01 AM |
