What calipers for rear vented rotors?, need advice |
914_1.8t |
Jul 3 2004, 11:56 PM
Member Group: Members Posts: 302 Joined: 3-June 04 From: East Bay Member No.: 2,149 |
I just picked up a rear 5lug converison complete with trailing arms. Just boleted the arms in.
The problem is that my calipers wont fit the vented rotors that the conversion came with (IMG:style_emoticons/default/headbang.gif) What caliper can I get to work with the vented rotors? Or am I better off getting 5 bolt rotors that are not vented? Are 914-6 rotors vented or will they work with stock 914-4 calipers. Appreciate any advice/help. |
Chris914n6 |
Jul 4 2004, 03:03 AM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
You can get spacers for the stock calipers.
You can use 914-6 rear rotors. You can use the appropriate 911 rear caliper. The most practical is the 914-6 rotors since you don't really need the vented rears on a -4. On a V8 I would do spacers to keep the parking brake with the vented rotors and use an aftermarket proportioning valve. Chris |
JFJ914 |
Jul 4 2004, 10:13 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Or if your /4 rotors are good, just drill the new 5 hole pattern in them. By the way, I used the /6 rotors. |
neo914-6 |
Jul 4 2004, 10:34 AM
Chris is right on
-There is a guy on this board building spacers -I'm not sure where to get 914-6 rotors -if you use the 911 caliper then you will need to adapt the 911 ebrake or find an alternative ebrake - mechanical, line lock, etc... Good luck, Felix |
914_1.8t |
Jul 4 2004, 11:54 AM
Thaks for you relies.
I think i'll try to drill my /4 rotors. If that doesn't work out, i'll pick up a set of the /6 rotors from Pelican Parts. |
914gem |
Jul 4 2004, 09:45 PM
Member Group: Members Posts: 91 Joined: 5-January 03 From: Greenwood Arkansas Member No.: 89 |
I have the 10mm spacers and O-rings for the rear 914 calipers.
thesey914 |
Jul 5 2004, 05:24 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
914GEM Did you have these made?
Do you have any more? Can we see a picture? |
davep |
Jul 6 2004, 07:13 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
search for the thread:
914-4 rear brakes with vented rotor, does anybody have/make/sell the spacers? I should be picking up additional items from the machine shop in a few days. I am having the hub spacers, the caliper spacers and the longer pad pins made. To get the longer bolts and the additional O-rings you may need to find a set of scrap 911 rear vented calipers. The O-rings are a 311 part and may still be available from VW. I cleaned out one warehouse a few years ago. The bolts are very hard to find: 7mm x 70mm. As soon as I can get pictures of the final parts I'll post in the resources section. I still don't know my costs, but hope to find out this week. Like most projects, this has taken several years plus a couple of months working with the machine shop. DaveP |
thesey914 |
Jul 6 2004, 08:11 AM
Nice work Dave....I had in the back of my mind that somebody was making some spacers.
I think you will get a lot of interest. Even if they're not really necessary.....who can resist 914 candy (IMG:style_emoticons/default/rolleyes.gif) |
davep |
Jul 11 2004, 05:55 PM
The kit for modifying 914/4 calipers to fit 20mm vented rotors is now in the Resources section.
Lo-Fi Version | Time is now: 28th May 2024 - 07:57 PM |
