> Battery tray, How to connect the ECU to the battery tray?
draganc
post Aug 10 2011, 12:36 PM
I’m installing a new battery tray and was wondering how the ECU mounting-bracket was originally connected to the battery tray? I have seen a few attached with screws and some are welded on?
Can anyone tell me what was original?
Thanks,
Dragan
championgt1
post Aug 10 2011, 12:42 PM
Don't embarrass me Filmore!
Attached with screws.
post Aug 10 2011, 12:45 PM
Resident German
QUOTE(championgt1 @ Aug 10 2011, 11:42 AM) *
draganc
post Aug 10 2011, 01:30 PM
Thank you and Danke!
Any pictures?
type47
post Aug 10 2011, 02:03 PM
Viermeister
6mm hex head bolts are used. There are holes in the "front" edge of the battery tray (the edge toward the .... well, front of the car) and the bolts screw into the ECU bracket. I think the front bracket piece "bends" or curves over the end of the ECU and 2 6mm cheesehead screws connect the curved piece to the bracket that is attached to the tray. That way, you can remove the ECU, leaving the bracket in place when you drop the engine. There must be another fastener at the other end of the bracket or the ECU would flop/vibrate on the 2 screwed end.
draganc
post Aug 10 2011, 02:56 PM
OK, let's make this idiot proof for me.
I can follow the comment about the two screw at the front of the tray but you lost me at "... I think the front bracket piece "bends" or curves over the end of the ECU and 2 6mm cheesehead screws connect the curved piece to the bracket that is attached to the tray...".
Here a picture of what I have.
Thanks,
Dragan
PS: The PO had the ECU bracket welded to the front and left side of the old tray.
r_towle
post Aug 10 2011, 02:59 PM
Custom Member
That is correct
jsayre914
post Aug 10 2011, 03:25 PM
Speed Up !!!
pics from a 73 2.0
post Aug 10 2011, 04:05 PM
Resident German
QUOTE(draganc @ Aug 10 2011, 01:56 PM) *
You are missing the front part of the bracket that curves downward. You'll need that to secure the front of the ECU.
draganc
post Aug 10 2011, 06:45 PM
QUOTE(SirAndy @ Aug 10 2011, 02:05 PM) *
Understood Andy! However, the pic that jsayre914 posted (thanks) shows that the bracket is fixed with one screw and two spot welds - on the long edge. Is that original?
Thanks,
d
draganc
post Aug 10 2011, 06:52 PM
PS: Can it be that there is a differance between late and early cars? I have seen now a few pics that have two spot welds and a screw and the side corner. Why spot weld and screw? I have a '75 2.0.
type47
post Aug 11 2011, 06:21 AM
Viermeister
QUOTE(draganc @ Aug 10 2011, 04:45 PM) *
Thanks,
d
Not original, just Joe's way of doing things (IMG:style_emoticons/default/happy11.gif) In Joe's pic, you can see the "curved piece" held to the bracket with the 2 (should be cheesehead) screws.
Parts can be viewed here:
http://www.914world.com/bbs2/index.php?showtopic=104293
r_towle
post Aug 11 2011, 07:39 AM
Custom Member
all of mine are held on with screws to the battery tray, and bolts to the ECU.
Rich
draganc
post Aug 11 2011, 07:54 PM
OK, now we have the proof in the puding! The braket I have is not original, it doesn't have the two 'press-in' nuts at the back. it's just a flat piece.
Thanks to all inputs!
post Aug 11 2011, 08:15 PM
Resident German
QUOTE(draganc @ Aug 11 2011, 06:54 PM) *
They probably just fell off. Those nuts are spot welded to the bracket and can come off fairly easy.
- Lo-Fi Version Time is now: 9th June 2026 - 01:22 AM
