1.7L oil bath air filter bolt length |
turnaround89 |
Aug 11 2011, 01:04 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Does anyone know the length of the bolt that holds down the oil bath air filter. I know that the bolt is gonna be M6x1.00 and was thinking it might be 120mm long, but not totally sure. Does anyone have one they can measure for me?
Thanks so much |
pt_700 |
Aug 11 2011, 02:00 PM
Senior Member Group: Members Posts: 1,092 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
if nobody else chimes in, i can measure mine after work today.
just the shaft length, correct? not including the little wing at the top? |
turnaround89 |
Aug 11 2011, 02:39 PM
yup, just the shaft length is all i need. Thanks so much
pt_700 |
Aug 11 2011, 08:30 PM
woohoo! good excuse to play with the micrometer! (IMG:style_emoticons/default/piratenanner.gif)
overall length from bottom of wingnut to tip - 120 mm or 4.75 in. threads - 14 mm or 9.5625 in. there's a little pointed tip to make it easier to find the hole - 3 mm or .125 in. |
turnaround89 |
Aug 11 2011, 10:14 PM
Awesome, Thanks so much.
Lo-Fi Version | Time is now: 20th May 2024 - 08:00 PM |
