Does anyone know the length of the bolt that holds down the oil bath air filter. I know that the bolt is gonna be M6x1.00 and was thinking it might be 120mm long, but not totally sure. Does anyone have one they can measure for me?
Thanks so much
pt_700
Aug 11 2011, 02:00 PM
if nobody else chimes in, i can measure mine after work today.
just the shaft length, correct? not including the little wing at the top?
turnaround89
Aug 11 2011, 02:39 PM
yup, just the shaft length is all i need. Thanks so much
pt_700
Aug 11 2011, 08:30 PM
woohoo! good excuse to play with the micrometer!
overall length from bottom of wingnut to tip - 120 mm or 4.75 in. threads - 14 mm or 9.5625 in. there's a little pointed tip to make it easier to find the hole - 3 mm or .125 in.
