| p914 |
Aug 12 2011, 10:52 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None |
Would 2 1000 cfs fans in the engine compartment mounted on the firewall aimed downward (not an extreme angle) and at the rear of the engine cool engine temps?
What other methods besides Nickys, Shrouds, Radiators are there? |
p914 Engine Temp Cooling Methods Aug 12 2011, 10:52 AM
johannes First question you should ask yourself is why does... Aug 12 2011, 11:12 AM
p914 A good question to ask. I should probably say thi... Aug 12 2011, 11:20 AM
Vacca Rabite 240? That's not even operational temp. Heads ... Aug 12 2011, 11:25 AM
p914
240? That's not even operational temp. Heads... Aug 12 2011, 02:01 PM
Vacca Rabite
240? That's not even operational temp. Head... Aug 12 2011, 05:33 PM
p914
For head temps, yes. Oil temps you don't wan... Aug 12 2011, 06:01 PM
904svo
[quote name='Vacca Rabite' post='1523531' date='A... Aug 12 2011, 06:35 PM
FourBlades Mount an additional oil radiator with fans.
Many ... Aug 12 2011, 11:28 AM
Bartlett 914 Lean conditions also make the motor run hot. Aug 12 2011, 11:52 AM
r_towle The stock fan is only going to pull a certain amou... Aug 12 2011, 11:54 AM
p914
Foley has created a new version of the top mounte... Aug 12 2011, 01:32 PM
76-914
Would 2 1000 cfs fans in the engine compartment m... Aug 12 2011, 07:12 PM
p914 Might want to get some ballast. Those 2 1000 cfs f... Aug 12 2011, 08:11 PM
Jake Raby I have a pair of the "twin barrel" upper... Aug 12 2011, 07:59 PM
Jake Raby But at very little velocity.. Electric solutions a... Aug 12 2011, 08:32 PM
SGB I've wondered about something simple-
scoop li... Aug 12 2011, 10:22 PM
Joe Owensby As someone mentioned, check your timing. Also, wi... Aug 15 2011, 06:29 PM
904svo Here is how I cooled my 914 engine.
Aug 15 2011, 07:28 PM
p914 I have an external oil cooling system I'm look... Aug 15 2011, 10:16 PM
p914 So as I was driving today I thought about my front... Aug 17 2011, 04:56 PM
yeahmag Ducting it right in to the tin is a bad idea in my... Aug 17 2011, 05:41 PM
Dave_Darling Where are you going to run those hoses and the duc... Aug 17 2011, 05:57 PM
aircooledtechguy I've always found that when you build/tune a m... Aug 17 2011, 06:08 PM
69telecaster Front air dam holes are small and a long way from ... Aug 19 2011, 07:58 AM
p914 Nice lookin car Telly Aug 19 2011, 01:55 PM
ellisor3 Here is what Joe at 914rs came up with for my six.... Aug 19 2011, 02:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:46 PM |
