Oil Pump |
Oil Pump |
newdeal2 |
Jul 5 2004, 09:00 PM
Unregistered |
On a stock rebuild is the stock pump good to re use or do you all recomend upgrading? I know Jake does a retro to a type 1 pump.
Anyone make a kit? Peter 74 2 Liter |
cary |
Jul 9 2014, 08:57 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Ok, I dropped the engine to find my oil leak. Has about 4k since my rebuild.
As I suspected the pump cover is leaking. Melling T1. So I have a couple questions. 1. Does the Melling use an O-ring? I didn't put one in during the rebuild. But I see the seat. 2. Should I get a T1 cover with the upper rim to keep it flat?I lapped the Melling cover, but I don't want to go back in there again. At least for a while. 3. Should I use oil pump cover nuts? If so, which direction? Flat down or rounded top into the hole in the top. 4. I used the thin gasket last time. Don't think I sprayed with copper coat. I'm going to try the 518 only this time. Any words of wisdom? |
Lo-Fi Version | Time is now: 17th May 2024 - 06:00 AM |
