Oil Pump |
Oil Pump |
newdeal2 |
Jul 5 2004, 09:00 PM
Unregistered |
On a stock rebuild is the stock pump good to re use or do you all recomend upgrading? I know Jake does a retro to a type 1 pump.
Anyone make a kit? Peter 74 2 Liter |
Mark Henry |
Jul 9 2014, 09:37 AM
10 year old post????
I still like to use the gasket and locktite 574, when I blueprint a pump the thin cover gasket is my clearance. On the cover gasket a hair of RTV rubbed (no excess at all) into the gasket. One thing on sealants is many builders have favorites, some are more modern and many will do the exact same job, clean surfaces is the real key. Arguing about which sealant is best is often just plain retarded. Melling pumps are crap, cast iron body has the wrong expansion rate with the aluminum case, it's too big and it will still need to be clearanced to work in a T4. Type one pump in a type 4 conversion always use a steel cover. |
Lo-Fi Version | Time is now: 18th May 2024 - 11:53 PM |
