914-6 Transmission Question for the historians |
pete000 |
Aug 12 2011, 10:12 PM
Did the 1971 914-6's come with a side shifter or was there a change over point going to the side shift configuration?
I know the 70's had tail shift. Also I have seen some 1972 914-6 with the ignition on the column, is that also correct? (IMG:style_emoticons/default/blink.gif) |
Cairo94507 |
Aug 12 2011, 10:32 PM
Michael Group: Members Posts: 9,772 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
The '71 six had a tail shifter; same as the '70/72.
The '72 six had the ignition on the steering column as they were using 4 cylinder steering columns for the '72. Personally I love the ignition to the left of the wheel as God intended. |
racerbvd |
Aug 12 2011, 10:53 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
Might also add that the 914-6 tail shifter is not the same as the 914 tail shifter..
Some of the 914-6s were converted later on, some complete trannies, others the "Six"" tranny converted.. |
Dr Evil |
Aug 12 2011, 11:08 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
All /6 are special tail shift. Conversion to side is not difficult, and is worth it according to those I have done it for (IMG:style_emoticons/default/smile.gif)
pete000 |
Aug 12 2011, 11:17 PM
I saw a 914-6 which had matching number trans, but it was side shift. I was wndering if it was a conversion. Is it possible to convert back ?
All good info ! (IMG:style_emoticons/default/smilie_pokal.gif) |
Dr Evil |
Aug 12 2011, 11:27 PM
Converting back and forth is easy.
Lo-Fi Version | Time is now: 20th May 2024 - 10:31 PM |
