Did the 1971 914-6's come with a side shifter or was there a change over point going to the side shift configuration?
I know the 70's had tail shift.
Also I have seen some 1972 914-6 with the ignition on the column, is that also correct?
Cairo94507
Aug 12 2011, 10:32 PM
The '71 six had a tail shifter; same as the '70/72.
The '72 six had the ignition on the steering column as they were using 4 cylinder steering columns for the '72. Personally I love the ignition to the left of the wheel as God intended.
racerbvd
Aug 12 2011, 10:53 PM
Might also add that the 914-6 tail shifter is not the same as the 914 tail shifter.. Some of the 914-6s were converted later on, some complete trannies, others the "Six"" tranny converted..
Dr Evil
Aug 12 2011, 11:08 PM
All /6 are special tail shift. Conversion to side is not difficult, and is worth it according to those I have done it for
pete000
Aug 12 2011, 11:17 PM
I saw a 914-6 which had matching number trans, but it was side shift. I was wndering if it was a conversion. Is it possible to convert back ?
All good info !
Dr Evil
Aug 12 2011, 11:27 PM
Converting back and forth is easy.
