The final journey begins, Weekend engine install(FINALLY!!!) |
East coaster |
Jul 6 2004, 05:54 AM
Senior Member Group: Members Posts: 1,680 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
Ron.......SHWEET! I'm glad you're a steps ahead of me, it really helps to see someone else go through this stuff first. How much of a PIA was it to get the motor in with the sheetmetal to seal interference?
I'm looking at your intake setup and mine is a little bit lower, so yeah! mine should fit without hitting!! I can't wait to hear what this things runs like!!! That will be truly inspiring. Mine is kind of dead in the water until I get my tranny back from Brad and so far it's been 4 months and I've heard nothing? (IMG:style_emoticons/default/headbang.gif) |
crash914 |
Jul 6 2004, 06:13 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Did you use the ATV jack to raise the engine? I have been thinking about getting one of those....saw a bunch of types at Harbor freight...herb
RON S. |
Jul 6 2004, 07:03 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
QUOTE(East coaster @ Jul 6 2004, 03:54 AM) it really helps to see someone else go through this stuff first. How much of a PIA was it to get the motor in with the sheetmetal to seal interference? I'm looking at your intake setup and mine is a little bit lower, so yeah! mine should fit without hitting!! On the sheetmetal quexchtun, The sheetmetal did just scrape the nuts on the trailing arms on both sides.Minor PITA but none-the-less it did need some massaging. What did suprise me was that the top of the 915 case rubs the bottom of the rear trunk crossmember when I tried to tighten the support bolts.I make some spacers for the bolts today while I'm here at work.That should make some clearance.Maybe it's just poor quality on the Vellios case,I don't know,but not a big deal. Ron |
RON S. |
Jul 6 2004, 07:07 AM
QUOTE(crash914 @ Jul 6 2004, 04:13 AM) Did you use the ATV jack to raise the engine? I have been thinking about getting one of those....saw a bunch of types at Harbor freight...herb Herb, I did try to use the ATV jack first,but I didn't think it'd work. I loaded a 2.4l on it and then tried to install a empty 915 case. Even with the jack fully extended as high as it'd go,the case wouldn't clear the fixed mounted jack where you'd have to pump. I had already made the dolly,so I used it instead.Worked just fine. Ron |
East coaster |
Jul 6 2004, 07:15 AM
I'm hoping the Wevo case will allow the 915 to fit without hitting the trunk. Maybe someday I'll find out (IMG:style_emoticons/default/wacko.gif)
East coaster |
Jul 14 2004, 08:10 PM
OK........the suspense is killing me, have you run it yet?? (IMG:style_emoticons/default/driving-girl.gif)
Lo-Fi Version | Time is now: 28th May 2024 - 09:01 PM |
