Bad Door switch, NLA, 944 switch works though |
phantom914 |
Jul 7 2004, 02:54 PM
non-914-owner non-club member Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 |
Maybe you already know this.
Anyway, I had a bad door switch and Pelican says NLA since two years ago. A local distributor said basically the same thing. Anyway, the 924/944 switch is identical in every way to my original except that the button is about 1/8" longer (oh and it's grey instead of black (IMG:style_emoticons/default/rolleyes.gif) ). I made sure that when the button is pushed all the way in, the switch does not come into mechanical interference inside the chasis. The only difference in operation is that the interior light comes on later (or turns off sooner) because of the longer button. Big deal. So trim the button if that bothers you. (IMG:style_emoticons/default/smile.gif) FWIW Andrew |
Jul 7 2004, 02:58 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
good info! (IMG:style_emoticons/default/smilie_pokal.gif)
i believe the handbrake switch is the same as well, it sure looks the same to me ... Andy |
Aaron Cox |
Jul 7 2004, 03:09 PM
cuz it is! they sent me 944 switch seals
phantom914 |
Jul 7 2004, 03:22 PM
QUOTE(acox914 @ Jul 7 2004, 01:09 PM) cuz it is! they sent me 944 switch seals That's how I found out about the switch. There were no pictures of the 944 switch, but when I got my seals, I noticed it said 924/944/930/914 so I took a chance (only $7.50) and bought the 944 switch and voila! Andrew |
rhodyguy |
Jul 7 2004, 03:54 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,063 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
they look identical to the ones in my 85' jetta. even the seal.
kevin |
Lo-Fi Version | Time is now: 28th April 2024 - 05:22 PM |
