Jack point rust, a little rust and a crack |
Tom |
Aug 18 2011, 10:14 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
I have a little rust and a crack on the bottom of the passenger side jack point.
Rest of longs, and hell hole is great. Should I just have the bad spot cut out and reweld in new metal, or replace the whole jack point piece. If replacing the whole piece is the right way, how do you remove the old one? Cut/grind it out or drill out the spot welds? Thanks, Tom Attached image(s) |
Lo-Fi Version | Time is now: 27th May 2024 - 07:22 AM |
