Tom
Aug 18 2011, 10:14 AM
I have a little rust and a crack on the bottom of the passenger side jack point.
Rest of longs, and hell hole is great.
Should I just have the bad spot cut out and reweld in new metal, or replace the whole jack point piece. If replacing the whole piece is the right way, how do you remove the old one? Cut/grind it out or drill out the spot welds?
Thanks,
Tom
rallysport70
Aug 18 2011, 10:26 AM
Speaking as an "East Coaster," I don't even see any rust......
beech4rd
Aug 18 2011, 10:55 AM
QUOTE(rallysport70 @ Aug 18 2011, 12:26 PM)
Don't believe this guy. Your car is toast. Suggest you advertise it on Craigslist in the Mid Hudson Valley for about $500.00. The check and the truck will be at your house tomorrow.
windforfun
Aug 18 2011, 12:29 PM
r_towle
Aug 18 2011, 01:04 PM
If that was me, I would cut off the bottom of the jack post.
For you, take a much closer look inside the jack post via the "drain hole" that IC is clogged with rust.
Clean that out with a pick and vacuum....then decide.
The problem is that the jack post is full, and has been full, of junk for many years...so the wall behind it is what most likely is rotted.
RIch
Drums66
Aug 18 2011, 05:26 PM
QUOTE(r_towle @ Aug 18 2011, 12:04 PM)
RIch
...The rust has a plan to attack the longs!!
Tom
Aug 19 2011, 01:05 PM
I'll order the whole jack point plate and when cutting out the rusty part see how far up behind it the rust goes and adjust replacement as necessary.
Thanks ,
Tom
Root_Werks
Aug 19 2011, 02:21 PM
That isn't bad at all Tom. I never use stock jack ports myself. For me, it would be clean up as much as possible, treat with ospho (or is it osfo?), paint and be done with it.
I know your 914 sees very, very little rain. I don't think this is a big deal at all.
windforfun
Aug 19 2011, 02:32 PM
Drums66
Aug 19 2011, 02:56 PM
.....Do it now or get fuched later...thats the way rust works
(don't play with rust)
Tom
Aug 19 2011, 03:15 PM
Dan,
Yep, I got caught in a light shower once!
The way I'm understanding is just cut/grind out the rust and preserve? I like that even better as I don't have a welder.
No, I never jack the car up with the jack points either. Just wanted to get the little bit of rust under control before it got out of hand. Had to remove the rockers to get the trailing arms off and noticed this.
Thanks to all for the suggestions,
Tom
jsaum
Aug 19 2011, 06:34 PM
QUOTE(Tom @ Aug 19 2011, 02:15 PM)
Dan,
Tom
Tom,
I have a small wire feed welder if you want to run a bead of weld across the crack.
Jsaum
Tom
Aug 19 2011, 08:06 PM
Thanks for the offer Jsaum. I think I will do this the easy way and just get rid of the rust and see what I need to do after that. Hopefully just cutting/grinding and preserving will be enough.
Thanks,
Tom
Aug 19 2011, 08:16 PM
And that crack looks like it's rusted through. Clean that up and poke (hard) with a flat screw driver. If you can poke through around the crack, it's time for some cutting ...
avidfanjpl
Aug 20 2011, 01:18 PM
I cut both out and had new ones installed with parts from the Canadian company.
It was worth it.
Both were packed with rust, but no damage to longs. It was good to know.
John
Click to view attachmentClick to view attachment
