Starters?, Rock and a hard place |
Razorbobsr |
Aug 20 2011, 05:48 AM
Member Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest |
ArtechnikA |
Aug 20 2011, 06:15 AM
I bought a high-torque "modern" starter for the 911 since I don't really care about originality in this regard. And they're lighter, so I figure it's something the factory wouldda done to an RSR if they'd had the option in 1973.
If you prefer to stay 'original Bosch' the 1,5-HP starters as used in the later cars will fit. (Our originals are 0,7 or 0,8 HP). They _are_ heavier, and only a little newer. But they do get replaced, usually by people going to the modern 'hi-torque' starter (which will sound different). But IMO, you have a solenoid, not starter, issue. These can be cleaned and regreased. Use a good quality synthetic grease like Mobil-1 or Royal Purple. |
Razorbobsr |
Aug 20 2011, 07:57 AM
I bought a high-torque "modern" starter for the 911 since I don't really care about originality in this regard. And they're lighter, so I figure it's something the factory wouldda done to an RSR if they'd had the option in 1973. If you prefer to stay 'original Bosch' the 1,5-HP starters as used in the later cars will fit. (Our originals are 0,7 or 0,8 HP). They _are_ heavier, and only a little newer. But they do get replaced, usually by people going to the modern 'hi-torque' starter (which will sound different). But IMO, you have a solenoid, not starter, issue. These can be cleaned and regreased. Use a good quality synthetic grease like Mobil-1 or Royal Purple. |
Razorbobsr |
Aug 20 2011, 08:19 AM
Drums66 |
Aug 20 2011, 11:16 AM
Why has no one suggested the "hot start kit" page 128 in the AA book and page 53 in the Performance catalog. I've been using these for 30 years in VWs and 914s . Simple and cheap insurance. easy install. ...I've used those in the past....I like it!! (IMG:style_emoticons/default/idea.gif) (band-aid or not)& it's not,if other things are fine!) (IMG:style_emoticons/default/idea.gif) |
Tom |
Aug 20 2011, 11:31 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
I also favor maintenance of the starter and solenoid. Be careful of using too much grease on the solenoid plunger. It will bake due to the constant heat and you will have the sticking solenoid again. A light coating of silicone high temp and then gently wiping excess off will suffice. Clean inside of the plunger bore also. While in there, clean and lube the plunger connections to the bendix and clean the electrical contacts.
Tom |
monkeyboy |
Aug 20 2011, 11:34 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
If the heat up there is the true issue, can you put a heat shield on it?
Rand |
Aug 20 2011, 12:06 PM
QUOTE (band-aid or not)& it's not Not only is it a band aid, this already has one and it isn't solving the problem. In fact, it could be the cause. A heat shield is another band aid. It needs a clean solenoid, not something else added that tries to compensate for a gunky solenoid. Jeez, I'm feeling almost as Krusty as the Cap'n. |
ThinAir |
Aug 20 2011, 12:46 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
If that link expires, search ebay for "porsche 914 mini starter" and look for vendor "hiperformanceofamerica" http://stores.ebay.com/hiperformanceofamerica I had hot start issues for years until I switched to a high torque starter from this vendor. I've put them in 3 type 4's and they perform wonderfully. I would never consider a reman Bosch based on my experience with them and would highly recommend the high torque. This vendor has some of the best prices around and is great to deal with. I highly recommend him. My previous starters had a hot-start kit installed. If you have a heat related starter/solenoid problem the hot-start kit won't help in the long run. I've been very satisfied with the high-torque starter solution. I've run it across the Mohave desert to WCR 2009 and go up to RRC each year and never have a starter problem anymore. |
Razorbobsr |
Aug 21 2011, 08:04 AM
rnellums |
Aug 21 2011, 05:20 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I've got a started off mine you can come get if you want to make the drive to Lafayette. Sorry I didnt get your reply until too late! I plan on being there, hopefully in calypso. |
Lo-Fi Version | Time is now: 4th June 2024 - 10:17 AM |
