If we're going to remake a 914, Might as well make it rust proof |
Aug 18 2011, 07:44 PM
914-6 GT in waiting Group: Members Posts: 19,296 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Stainless Steel - Made by Porsche to test out non corrosive materials - http://retro-motoring.blogspot.com/2009/09...-steel-car.html
Mike Bellis |
Aug 18 2011, 07:47 PM
I know a company in LA that will make you a Carbon Fiber Uni-body! it will cost you $$$$ though...
Cairo94507 |
Aug 18 2011, 07:53 PM
Michael Group: Members Posts: 9,791 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I would like to find a place that dips the whole body to seal it like they do now when they are built. Does anyone do that?
Mike Bellis |
Aug 18 2011, 08:00 PM
I would like to find a place that dips the whole body to seal it like they do now when they are built. Does anyone do that? There's a place near Fresno that has a BIG galvanizing tank. You would need an acid dip first, fix all the rust and then Galvanize dip. |
Cairo94507 |
Aug 19 2011, 06:22 AM
Mike,
Soda blasting won't do? I would prefer not to get the car dipped in acid...you never know it might disappear. Thanks. Michael |
smontanaro |
Aug 19 2011, 10:48 AM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Porsche was hardly first to the stainless steel body game. To wit: 1936 Ford.
Rob-O |
Aug 19 2011, 03:11 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Not to mention that you'll lose the heater tubes if you don't cut off the longs and pull the tubes out first. Ask me how I know...
Mike Bellis |
Aug 19 2011, 03:34 PM
kharma |
Aug 20 2011, 07:06 AM
Member Group: Members Posts: 68 Joined: 13-November 07 From: Billerica MA Member No.: 8,328 Region Association: North East States |
Pretty cool, I just saw one of these last weekend at the Saratoga Auto Museum. Apparently they made 6, there are 4 remaining. |
smontanaro |
Aug 20 2011, 10:19 AM
you would have to acid dip it to get to all the places liquid will flow and soda blasting won't reach. ie: Longs Hmmm... Has anyone considered just dipping enough of the body to get to all those low down hidden places, like inside the longs, then using a milder method like soda blasting to do the rest of the body? S |
HarveyH |
Aug 20 2011, 02:27 PM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
At the end of the 1960 production run Allegheny Ludnum contracted for two stainless steel 1960 Thunderbirds. The bodies were stamped on the production line at Budd in Philadelphia. Apparently both still exist, one at teh Heinz Museum in Pittsburgh, and I think Thyssen-Krupp took the second one when the Budd plant in Philadelphia closed. My father worked at Budd, but I don't know if he was involved in this project. Article on the T-Birds Harvey |
charliew |
Aug 20 2011, 03:21 PM
Soda is only for removing paint and eventually body filler. Sand is for removing rust or acid. The acid dip was a trick in the late 60's to get drag cars weight down. The truck was to know how long to leave it in the bath to get the right thickness. I had two scout 800 gas tanks dipped at the radiator shop and one of them didn't come out of the solution. Also the acid dip will require a second solution to neutralize it, then the galvanize.
Ss is a lot heavier than mild steel, also it's a lot harder on the tooling. |
bembry |
Aug 20 2011, 10:19 PM
Senior Member Group: Members Posts: 529 Joined: 29-July 05 From: Bakersfield, CA Member No.: 4,499 Region Association: MidAtlantic Region |
I don't really even like 911s, but that car is a work of art!!! Absolutely beautiful!
URY914 |
Aug 21 2011, 07:00 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,863 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Here's a Autocar that has been sitting outside in New Jersey for years....
Lo-Fi Version | Time is now: 28th May 2024 - 05:30 AM |
