Help with six clutch issue, Appears to not be rel;easing |
sixaddict |
Aug 21 2011, 09:36 AM
Senior Member Group: Members Posts: 801 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
I have a mysterious recurring issue.
CAr specs: 74 conversion with 3 liter/carburated and 901. Not sure of clutch mfg. Clutch appears to not be releasing but only after the car gets hot. This happened last year at the track and we adjusted clutch (even changed cable)...it worked for one session; then came back. Got home tore trans out to check pivot bushing all was intact. Couple weeks ago at AX it started clashing 1st once it go hot. Had it in shop for other issue. Brought it home and drove for thirty minutes to get inital heat cycle on new tires. Once hot it started clashing 1st and reverse...to the point I had to shut it off put in first or reverse. It was fine when cooler but progressed to being uncomfortable. Clutch adjustment seems too short lived so looking for thoughts on potential issue. Thanks for the input. Terry |
rgalla9146 |
Aug 21 2011, 01:11 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I have a mysterious recurring issue. CAr specs: 74 conversion with 3 liter/carburated and 901. Not sure of clutch mfg. Clutch appears to not be releasing but only after the car gets hot. This happened last year at the track and we adjusted clutch (even changed cable)...it worked for one session; then came back. Got home tore trans out to check pivot bushing all was intact. Couple weeks ago at AX it started clashing 1st once it go hot. Had it in shop for other issue. Brought it home and drove for thirty minutes to get inital heat cycle on new tires. Once hot it started clashing 1st and reverse...to the point I had to shut it off put in first or reverse. It was fine when cooler but progressed to being uncomfortable. Clutch adjustment seems too short lived so looking for thoughts on potential issue. Thanks for the input. Terry I'd check the clutch guide tube in the tunnel. Proly broken loose from its mounts. Any funny noises when you floor the clutch pedal ? ( engine off ) Look up repair methods in the forums |
sixaddict |
Aug 21 2011, 03:50 PM
Hate to be a DA but how to check tube mounting
Aug 21 2011, 09:03 PM
Pull up the center tunnel carpet so you can look through the gap in the gear shift lever assembly and the holes in the top of the tunnel. Look for a tube inside the tunnel that moves left and right when you push on the clutch pedal.
Also look under the car where the cable comes out of the center tunnel while someone else pushes the clutch pedal. The tube may move around at the firewall. Movement in either place is a bad sign and means some welding is in your near future. --DD |
sixaddict |
Aug 22 2011, 08:09 AM
Dave :
Thanks for the help....... Terry Pull up the center tunnel carpet so you can look through the gap in the gear shift lever assembly and the holes in the top of the tunnel. Look for a tube inside the tunnel that moves left and right when you push on the clutch pedal. Also look under the car where the cable comes out of the center tunnel while someone else pushes the clutch pedal. The tube may move around at the firewall. Movement in either place is a bad sign and means some welding is in your near future. --DD |
Lo-Fi Version | Time is now: 15th May 2024 - 12:21 PM |
