916 bumpers |
916 bumpers |
MarkG |
Jul 9 2004, 02:42 PM
Member Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
My '76 should be here in 10 days or so, want to remove the heavy bumpers and replace with fibregalss units.
Any input on best quality 916 bumpers (or even early style bumpers in glass)? I see several suppliers out there. Thanks! |
Bigbohr |
Jul 9 2004, 03:00 PM
Superlurker Group: Members Posts: 224 Joined: 19-September 03 From: Houston, TX Member No.: 1,176 |
I have or have seen FG stuff from Tweeks, Rennspeed and Pelicanparts, and would recommend Tweeks. More expensive but quality seems better. Be warned that it took them a looooooong time to deliver. It looks like Pelican sells the same stuff as Tweeks. At least the PP rockers look like family of the Tweeks 916 rear bumper.
propricer |
Jul 9 2004, 05:41 PM
Member Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
Also consider going directly to the manufacturers such as AIR ( www.americaninternationalracing.com ) at 626.969.7733
or GT Racing ( www.gt-racing.com ) at 800.797.2911 Both are good ... |
Phoenix-MN |
Jul 9 2004, 06:55 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
I used Tweeks parts and they were POS, but in all fairness I think they have several suppliers and the ones I received took about 40 hours of work to fit right. I have many pictures of the poor fit and the work I did to get them to fit right. I talked directly with the supplier and they wouldn't give me the time of day and Tweeks would not let me return them since I had them for 6 months (should have test fitted them right away - my fault)
Bottom line - fiberglass parts vary greatly from one supplier to another, they are all going to need work to fit good. Paul |
smg914 |
Jul 9 2004, 10:48 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
If you decide to purchase the glass GT bumpers, be aware that some are sold without any attachment brackets (GT Racing). For these you have to purchase brackets seperate and have someone attach them to the bumpers before you can put them on your car. There are other places that sell them with the brackets already attached.
jgiroux67 |
Jul 9 2004, 11:41 PM
Guitar Shredder Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 |
I just got f/g 916 front and rear bumpers, gt rockers, full front fenders, rear flares from rennspeed. They are of pretty good quality but have a whole lot of fitting that is needed. Also the bumpers came with mounts molded in, but they didnt match up correctly so im gonna have to make some adjustments.
maf914 |
Jul 10 2004, 07:04 AM
QUOTE(Phoenix-MN @ Jul 9 2004, 04:55 PM) I have many pictures of the poor fit and the work I did to get them to fit right. Paul Paul, I would be interested, and I think others would too, in seeing your photos of the work you did to fit your fiberglass pieces. Post them if you can. Thanks. |
Phoenix-MN |
Jul 10 2004, 08:36 AM
Front shot - top should be straight with no sags. Was taken out of the mold too soon.
Phoenix-MN |
Jul 10 2004, 08:38 AM
Large gap from top of bumper to top of hood
Phoenix-MN |
Jul 10 2004, 08:40 AM
Right side - No comment
Phoenix-MN |
Jul 10 2004, 08:41 AM
Left side - no comment
Phoenix-MN |
Jul 10 2004, 08:43 AM
I used high density urathane foam to build up the surfaces
Phoenix-MN |
Jul 10 2004, 08:45 AM
After adding all the foam
Phoenix-MN |
Jul 10 2004, 08:47 AM
After shaping
Phoenix-MN |
Jul 10 2004, 08:49 AM
After fiberglassing, filling, sanding, and priming
Phoenix-MN |
Jul 10 2004, 08:54 AM
The rear bumper did not require much fiberglass work but did require one heck of a lot of triming to fit properly. The finished parts can be seen at http://phoenixhobbies.com/html/project_914.html under paint work.
Paul |
maf914 |
Jul 10 2004, 09:09 AM
Paul, Thanks for the photos. Good job. It looks like you know what you're doing. I would not have known where to start a repair like that. It's a shame that after spending two to three hundred for the bumper you still have to rebuild it to fit right.
Where can one buy high density urathane foam? BTW, I visited your site. Great project and great work. Did you do the painting yourself? In the garage? How did you keep the garage clean of overspray? What is the status of your car now? |
Phoenix-MN |
Jul 10 2004, 10:51 AM
I got the foam at Composite Structures Tecnology CST, I've done all the body and paint work myself (learned from a buddy that was a professional body man) Garage is a mess (IMG:style_emoticons/default/blink.gif) but what the heck. I have the front and rear deck lids back on, the wiring harness back in, front and rear suspension attached, tails lights installed, driving lights installed along with horns and today I'm working on getting the fuel and brake lines bent and installed. Tomorrow the steering rack and turbo tie rods go in and I will finish up with the duct work for the radiator. Now that most of the "big jobs" are out of the way, assembly goes rather quick (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 15th May 2024 - 01:45 AM |
