foglight rewire trick?, 1972 |
Thestigz06 |
Aug 22 2011, 10:31 AM
Aspiring Jarhead Group: Members Posts: 238 Joined: 22-February 11 From: Temecula, CA Member No.: 12,749 Region Association: Southern California |
Howdy all,
i been having trouble with the foglight rewire tick (running foglight with the headlights down) can anyone explain it to me again? |
dlestep |
Aug 22 2011, 10:39 AM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
Howdy all, i been having trouble with the foglight rewire tick (running foglight with the headlights down) can anyone explain it to me again? ...on my '73, I simply supplied power to the fog lights by moving the power source from aft side of the switch to the forward power source. (power to the fog in the first switch position). |
Bruce Hinds |
Aug 22 2011, 10:42 AM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
the fogs are powered off the low beam fuse. I use driving lights so I switched the leads to the high beam fuses.... I'd imaginge just find the fuse that's hot with the key on and you're good to go.
underthetire |
Aug 22 2011, 12:00 PM
If you don't mind spending 25 bucks, the Jwest kit is really nice. Good instructions as well. I do like the flash to pass feature as well.
elmonte |
Aug 22 2011, 05:58 PM
Member Group: Members Posts: 225 Joined: 31-March 03 From: Danville.ca Member No.: 499 |
Black22 |
Aug 22 2011, 07:12 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) That's those are the instructions I used. My fogs can be used with or w/o the headlights being on. Also if the fogs are on by themselves, pulling back on the turn signal stalk turns them off momentarily to "flash" other drivers. They will also turn off if the high beam headlights are engaged. Perfect for my needs.
Aug 22 2011, 08:28 PM
If you don't mind spending 25 bucks, the Jwest kit is really nice. Good instructions as well. I do like the flash to pass feature as well. (IMG:style_emoticons/default/agree.gif) |
jim_hoyland |
Aug 22 2011, 08:47 PM
Get that VIN ? Group: Members Posts: 9,292 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Is there a wiring diagram available showing how the JWest fog light flash is installed ? I bought one used at the G & R swapmeet, but the instruction were gone. (IMG:style_emoticons/default/sad.gif)
underthetire |
Aug 22 2011, 08:53 PM
Is there a wiring diagram available showing how the JWest fog light flash is installed ? I bought one used at the G & R swapmeet, but the instruction were gone. (IMG:style_emoticons/default/sad.gif) I know I kept mine, but where I kept it is a different story. I'll dig around. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:17 PM |
