Lube?, Tranny Shifter |
Razorbobsr |
Aug 22 2011, 11:13 AM
Member Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest |
The parts of the shift linkage and are under the very rear of the car... Catch alot of road crud, dirt, etc, I cleaned mine off today while thinking of that top starter bolt but now I wonder???????? Lube?? With?? How often? Thanks, Bob
Drums66 |
Aug 22 2011, 11:31 AM
.....My rule is.......anything outside the boots or protective cover(don't lube) (IMG:style_emoticons/default/idea.gif) bushings lightly with, silicone or white lithium (IMG:style_emoticons/default/idea.gif)
and I've never had issues concerning this!!(decades) (IMG:style_emoticons/default/bye1.gif) |
ArtechnikA |
Aug 22 2011, 12:30 PM
The parts of the shift linkage and are under the very rear of the car... Catch alot of road crud, dirt, etc, I cleaned mine off today while thinking of that top starter bolt but now I wonder???????? Lube?? With?? How often? Thanks, Bob You don't say what year car or what kind of transmission... Tailshift cars are supposed to have a black plastic shroud around the linkage bits. Like most '70's plastic these didn't fare well with north American UV and ozone. They were also kinda fragile to start with, and held in place only by a rubber O-ring (that wasn't any more exposure-proof than the enclosure). They've been NLA for years, but you might have a look at the parts book to see what they once looked like. I always thought you might be able to make some kind of shield / bag out of a chamois or something. Those parts were originally greased, and the shroud kept the grease in and the grit out. |
Razorbobsr |
Aug 22 2011, 01:27 PM
ArtechnikA |
Aug 22 2011, 01:48 PM
Cupomeat |
Aug 22 2011, 01:57 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Side shifter should have covers over all the moving/sliding bits.
There should be a rubber boot on the firewall bushing that covers the connector. There should be a large 4"x4"x2' black plastic cover that goes on the side shift mechanism. Buy them both, lube the bits that slide and don't worry about it. I hope that helps. |
Razorbobsr |
Aug 22 2011, 02:22 PM
Side shifter should have covers over all the moving/sliding bits. There should be a rubber boot on the firewall bushing that covers the connector. There should be a large 4"x4"x2' black plastic cover that goes on the side shift mechanism. Buy them both, lube the bits that slide and don't worry about it. I hope that helps. Dont have that boot, can they be bought? Bob |
Lo-Fi Version | Time is now: 15th May 2024 - 12:57 PM |
